Italeri 1/24 Lancia LC2
    With the BMW coming close to a finish, my next build will be this
    I've already done an in-box review here https://www.scale-models.co.uk/threa...-review.39133/
    Looking at the model a bit closer, it's a bit crude, and purely a kerbside model, absolutely no engine at all. The construction look simple, but I reckon the decals are going to be a little tricky, mainly because of this
Name:	wing louvres.jpg
ID:	1175659 And the decal that fits over the louvres
Name:	transfer problem.jpg
    I don't know if my normal decal solution will cope with that, so I might have to dig out the Humbrol Decalfix. That's a bit fierce, so it's not normally used.
    The cab is a bit bare, so I reckon I'll use the racing driver ( with full face helmet ) from this
Name:	fujimi drivers.jpg
    You get one racing driver body, 3 separate heads with differing helmets. The other figures will languish in the spares box. I did look at a 1/24 resin figure, but that was more expensive, alone than the Fujimi box!
  • PaulTRose
    • Jun 2013
    • 6460
    • Tattooine
    oooo nice...dont think ive seen this one done before........good luck with the decals
    Per Ardua
    • JMARC
      • Sep 2008
      • 352
      Interesting choice ..I'm getting myself some POP-CORN and a large DrPopper so I can follow this one and the other you have started ...Go,go,gooo !
        After the Revell BMW M3, this is a much simpler build it's just a kerbside model, with no pretensions of unnecessary detail - the cab is a bit bare, but the driver will fill the space. The model can be made with the doors open, but looking at the hinges, that doesn't look very good. Some of the construction is distinctly old school - pivot pins with the tops melted with a heated screwdriver!
          This is the driver from the Fujimi set:
          I'll have to do a bit of digging to see what colour the suits were, and if either MIchele Alboretto, or Ricardo Patrese had distinctuve helmets. I'll have to make some 6-point seatbelts up, possibly masking tape..............
          Chassis underway..................
          That's it, more or less - a simple rod for a rear axle - couldn't be simpler - I hope that there will be head clearance for the driver, otherwise, the dremel may make a brief period of use, to remove the drivers backside & thighs!
            • 15689
            Hi Dave
            Looks straightforward apart from the decals.
              The daylight revealed a couple of sink marks in the bodywork, so a dab of filler was used before priming ..............
              One prime coat & a basecoat - I'll leave that overnight to see if I need another white coat before moving onto the gloss varnish.
              Tub sprayed aluminium, and the rest of the chassis black
ID:	1175994 Wheels assembled, ready for the tyre walls to be gloss varnished, prior to adding the Pirelli decals. It is a very simple model not many pieces to add............
                Two coats of gloss varnish, then I need to add the transparencies before starting the decal process................
                The wheels have had their decals added, and the instrument panel added. The driver has had some seatbelts added from masking tape & a buckle from scrap plastic..............
ID:	1176013 The suit was white/off white & I've found the helmet colours
                Albaretto
                Patrese - I think the simpler colour........................
                • adt70hk
                  • Sep 2019
                  • 10409
                  Coming on nicely Dave.
                  Definitely the Patrese helmet I think!
                    First major problems! The transparencies are a very poor fit & need a bit (!) of fettling, just to get an approximate fit. Now, onto the decals.................
                    The instructions don't show any painting on the window frames, but when you apply the decals, this is what you find......................
                    Not impressed, to say the least....
                    After drying the decals - the frames are touched up.................
                    As to fit - I've had to open up all locating holes, nothing too difficult, but rather annoying. I'm afraid this just confirms my long held impressions of Italeri as a second tier manufacturer. The model is basic & really shows it being made to a tight budget - this cost me ยฃ19 delivered from ebay, and that's what it's worth.
                    I may change my mind ( for the worse ) when I start to apply the stripe decals................
                      Can't say I have really enjoyed applying these decals, not easy getting things to line up - I've only done one side so far..................
                      Abut the only good thing I can say is that they're pretty tough! At the moment the decal solution part#2 is at work - it ( hopefully ) will draw the decal down ( the wrinkles will disappear... ) - It may need another application later night. Italeri give you the option of having the doors open, but when it comes to the decals there's no guidance for this. In the background, the driver is waiting impatiently................
                      • Lee Drennen
                        • 7711
                        Nice one Dave I know you will turn this thing into a Beautiful Race car.
                          Even though I knew how all the decals went on, the other side wasn't any easier ( or enjoyable! ) All I can say is that I wouldn't want to attempt this without decal solution!!
                          There are a few gaps, where the decals don't quite meet - I'll let the decal solution do its' work overnight, and maybe attempt a little touching up to hide the errors.
                          These will be the last pictures in the under construction section
                          I've done 3 cars in quick succession, and I feel a change in genre coming on.............maybe something floaty, but whether a complete new build, or picking up a shelf queen.....................
                            completed https://www.scale-models.co.uk/threa...mpleted.39442/
