VanDub
  • Mark1
    • Apr 2021
    • 4156
    VanDub
    Hi all, i have recently acquired a couple of vw kits for a build idea ive had for a whileClick image for larger version
ID:	1182538 and that is to make something like this.Click image for larger version
ID:	1182539first thing i had to do is cut the beetle in half as the back wont be neededClick image for larger version
ID:	1182540. Then starting with one side of the van panel i have first cut to the required lengthClick image for larger version
ID:	1182541 then the next issuse is the raised swage line along the middle had to be done away with and made to look more like the beetle swage lineClick image for larger version
ID:	1182542 so i cut along the bottom of the line and done a fair bit of sanding and glued the panels back together leaving something morelike i was afterClick image for larger version
ID:	1182543Click image for larger version
ID:	1182546 i have cut some evergreen sheet and shaped it to create the door shut/b post. Ive removed the louvers from the lower part of the panel ,sanded the join and then applied some fillerClick image for larger version
ID:	1182544 which has been sanded still needs some more work but have given it a coat of primer just to see how its looking so far Click image for larger version
ID:	1182545the other side will require a bit more work as the panel section is shorter and i have had to cut and glue the side loading door in to make the extra length this will then be trimmed down to size, louvres and petrol flap will be removed ,the beetle has the petrol flap just above the front wing. Click image for larger version
ID:	1182548Click image for larger version
  • Code no 10
    • Jun 2022
    • 130
    Very nice "Pimp my VW", Mark. :thumb2:
    • Mini Me
      • Jun 2018
      • 10711
      Outstanding bit of "Bashery" there Mark. It is helpful that you have a pic. to work from for the basic concept, the rest is pure creative Genius! :thumb2:
      • adt70hk
        • Sep 2019
        • 10413
        Now that's different!!
          • 18911
          Nice job. Primer is showing the cut and shut going well.
            • 15714
            Something different. Looks as if you're well on the way. Neat looking cut and shut work.
            • PaulTRose
              • Jun 2013
              • 6474
              • Tattooine
              im liking where this is going
              Per Ardua
              • The Smythe Meister
                • Jan 2019
                • 6248
                Yep,
                Very interesting, and "different"
                Coming along great too Mark, excellent stuff!
                Andy
                • PaulinKendal
                  • Jul 2021
                  • 1608
                  • Kendal
                  This is great, Mark - I love this sort of thing: takes some nerve to be so bold! Great job so far!
                    • 18271
                    Nice bit of chop and section work that.
                    How is the roof line up?
                    • tigersteve
                      • Jan 2018
                      • 678
                      Nice work so far - as the 'Beetle' was my first car (many decades ago) I shall be watching with interest ! Have fun !!
                      • Mark1
                        • Apr 2021
                        • 4156
                        Cheers guys thanks for looking in.
                        At the moment its like a size six foot in size twelve boot lol, i think thats gonna be the trickiest part,lots of chopping about will be needed.
                        • Mark1
                          • Apr 2021
                          • 4156
                          So ive made a bit more progress today,the other side panel will need a bit more filler but is coming along okClick image for larger version
ID:	1182576.as im using a fair bit of filler im using this stuff.Click image for larger version
ID:	1182577until i have the body joined up with the front half via the sill panels and roof ive add some braces inside so i can handle it as one sectionClick image for larger version
ID:	1182578,this will make things easier as far as making a roof which is gonna take some doing Click image for larger version
ID:	1182579and also i have to rework the tailgate swage so same as the sides and then rework the whole back end so i can get a tailgate fitted,Click image for larger version
ID:	1182580the braces will then be removed from inside,l will be chopping a lump off the lower rear corners as they are far to low,Click image for larger version
ID:	1182581 the rear wings have been removed from the beetle and i have made start on reshaping them to fitClick image for larger version
                          • Mark1
                            • Apr 2021
                            • 4156
                            Have made a start on the roof,plenty of cuttingClick image for larger version
ID:	1182585,i will be using two sections of the van roof,cut to length and narrowed considerably the curvature is a very good match for the beetle roofClick image for larger version
ID:	1182586 and the gutterline is virtually spot onClick image for larger version
ID:	1182587 although it will need sanding back as its well oversize,this is all just a rough dry fit at the moment.
                            • Mini Me
                              • Jun 2018
                              • 10711
                              That is some marvelous "Plastic" Surgery you are doing Mark. I'd say the patients chances of pulling through are better than excellent!! :thumb2: :thumb2: :thumb2:
