VanDub
  • Mark1
    • Apr 2021
    • 4156
    #16
    Originally posted by Mini Me
    That is some marvelous "Plastic" Surgery you are doing Mark. I'd say the patients chances of pulling through are better than excellent!! :thumb2: :thumb2: :thumb2:
    Thanks Rick its getting there.
      • 15725
      Hi Mark
      Much chopping and fitting going on. It certainly looks as if you're getting there.
        • 18271
        This it some nice customisation this.
        Have you considered dropping the roof while you're at it..? Lol.
        I have had a long time urge to drop a samba bus onto a landy chassis
        • Mark1
          • Apr 2021
          • 4156
          #19
          I hadnt actually thought of that but i think im going for the 'it could have come from the factory look'maybe ill drop the suspension a bit.
          I have a hilift toyota hilux in the stash and the remains of the bus! :thinking: you may have given me an idea lol.
          • Mark1
            • Apr 2021
            • 4156
            #20
            Ok so the bit i was most not looking forward to is done ,ive now got a complete roof. The lump of plastic in the back is just to keep the back edge straight until the glues dry,next up is to join the body via the sills to make it more rigid as nothing can be stuck to the floorpan yet as theres gonna be a whole heap of interior to sort out and im still debating if i can makes some suitable hinges so ive got opening front doors,plus all the extra interior work this will create.Click image for larger version
ID:	1182663Click image for larger version
ID:	1182664Click image for larger version
ID:	1182665and also ive made a start with the engine,Click image for larger version
ID:	1182667Click image for larger version
            • Mark1
              • Apr 2021
              • 4156
              #21
              Well i have been busy sanding and thanks to the white plastic being very thick the roof has levelled out quite nicely,there is a swage line on the beetle roof i have sanded into the white plastic to blend it in ,i have done away with the gutters as it gives a cleaner look and to fill and sand round them would be a nightmare,next i will reshape the tailgate and its aperture,also the engine lid will need to be sussed out and then it will ready for filler and many hours of sanding, oh joy!!Click image for larger version
ID:	1182743Click image for larger version
ID:	1182744Click image for larger version
ID:	1182745Click image for larger version
              • Mini Me
                • Jun 2018
                • 10711
                #22
                Jusssst Luverrrrly Mark
                • tigersteve
                  • Jan 2018
                  • 678
                  #23
                  Looks like your having fun !!
                  • yak face
                    • Jun 2009
                    • 13842
                    • Tony
                    #24
                    Superb quality butchery going on here mark , right up my street! The cut’n’shut is looking seamless now , youre doing a brilliant job , cheers tony
                    • Mark1
                      • Apr 2021
                      • 4156
                      #25
                      Cheers guys, first time ive tried anything like this,some lessons learned already how i can do this differently next time but enjoying the challenge.
                      • Mark1
                        • Apr 2021
                        • 4156
                        #26
                        Quick update,the tailgate has been narrowed by 7mm and the top of the window frame lowered about 3mm,headlining has been cut down to fit the cab section and i have started removing the chrome trims that are mould to the front half as there not on the rear half and not something i can replicate to match.Click image for larger version
ID:	1182818Click image for larger version
                        • JR
                          • May 2015
                          • 18273
                          #27
                          Remarkable work Mark , very skilled and beautifully done .
                          • adt70hk
                            • Sep 2019
                            • 10416
                            #28
                            Coming on very nicely!!!
                            ATB.
                            • Mark1
                              • Apr 2021
                              • 4156
                              #29
                              ATB.
                              Cheers chaps,
                              Probably more luck than skill lol.
                                • 15725
                                Excellent work. Everything looks to be coming together nicely.
