Revell Shelby Cobra 62 1:24
  • mog
    • Mar 2020
    • 139
    Building this for a friend. First, I’m not a car guy. I have built some military vehicles, but very few plastic builds. Still a ship and wood guy at heart. However, the challenge is moving out of the comfort zone. So, the next three builds on the bench will not be ships.
    The cobra I have moved along rather quickly, The body color 4 coats 8 to 2 mix of Revell # 52 blue and Vallejo steel. I have basically followed the instructions, making a few modifications, shortingClick image for larger version
ID:	1184571Click image for larger version
ID:	1184572Click image for larger version
ID:	1184574 the axles, drilling new holes to get a better fix on some parts. For example, the engine did not fit squarely on the chassis, the mounts caused it to lean to one side slightly, so I drilled a hole thru the right-side mount into the engine block, inserted a pin to hold the block level. The rear axle housing had to be shortened on the right side to get a proper fit with the brake discs. Again, some mounting holes were slightly off. I read some builders reviews on this build saying the same thing, of course as stated I’m not a car guy and a little rusty with my plastic skills, so I could have misaligned a part or two along the way. All in all I’m pretty happy with the progress so farClick image for larger version
ID:	1184573Click image for larger version
ID:	1184575Click image for larger version
ID:	1184593Click image for larger version
ID:	1184594Click image for larger version
  • mog
    • Mar 2020
    • 139
    completed interior minis, a few touch ups I think it came out ok,
ID:	1184966Click image for larger version
ID:	1184967Click image for larger version
      • 18912
      Looking good Mike
      • Mark1
        • Apr 2021
        • 4156
        So far so good
        • Mickc1440
          • 4779
          Love the Blue
          • mog
            • Mar 2020
            • 139
            Shell complete, 2 coats of semi-gloss clear coat Click image for larger version
ID:	1185092Click image for larger version
ID:	1185093Click image for larger version
            • Mickc1440
              • 4779
              Keeps getting better
              • mog
                • Mar 2020
                • 139
                completed back drop for the Shelby Click image for larger version
ID:	1185138Click image for larger version
