Hello all, I have recently purchased a Kit of a Mk1 Ford Escort in 1/12 scale.
This is not from any of the major manufacturers (they've missed their chance there...) but is from a guy in Germany who 3D prints them.
Its the first time I've had any kit like this. It has no instructions (it really doesn't need any) and a lot of the sub-assemblies come in one piece, e.g. the whole back axle has the springs and dampers attached. Its going to be quite a challenge as the surface of all the parts is quite heavily ridged and the main body is split down the middle (I presume due to the size of his printer) and distorted at the point it joins together (have a look at the pictures)
I would value your advice if you have worked with similar things before e.g what the best glue to use? I'm not even sure what its made of, certainly not the normal styrene. Do they use some form of resin?
I think it will take me the rest of the year and through the winter just to get the body right! But I'm looking forward to the end result as I have plans for the paint job.
Any advice appreciated.
