Bandai 1/16 Rolls Royce Silver Ghost 1908 - "Balloon Car"
    • 18908
    Reading up on it I think Pete might well be right with cascamite. “Dries glass hard and impervious to water” is how it’s described and that seems to mirror your experience Jim. The only remover I can find described is acetone. Try it with a spot of nail varnish remover if you have access to it. Good call Pete :thumb2:
    • JR
      • May 2015
      • 18273
      #17
      I'm in Jim.
      Looks a beast of a build, with out doubt you will manage it well.
      • Tworrs
        • Jan 2022
        • 1982
        • Garry
        • New Zealand
        #18
        Looking good so far Jim, I'm sure your fettling skills are well up to the challenge.
          • 15709
          I tried acetone without any effect. Luckily it is brittle and with patience can be chipped away. I have cleaned up all the chassis parts - side rails and cross pieces and started to fit it back together.
          Thanks for your interest and suggestions.
          • Si Benson
            • 3572
            #20
            Evening Jim, great to see your busy with a bit of a challenge and something not many of would tackle.
            Looks like your off to a great start :thumb2:
            I keep a bottle of fairy power spray for stripping back too….does a good job :smiling4:
            • Waspie
              • Mar 2023
              • 3488
              • Doug
              • Fraggle Rock
              #21
              Blimey Jim, looks like you enjoy a challenge. Good luck, although it looks like you're off to a superb start!!
                • 15709
                Thanks guys for your support. It means a lot.
                Sanded back the ends of that cylinder thing. The original was beyond clean up :sad:
                The little oblong bits fitted back onto the block.
                All the bits that had had a Fairy Power Spray bath have been cleaned up. The cylinder needed a lot of sanding which destroyed the 4 bands so replacements were made from pewter.
                And most satisfying of all we have a chassis that is square and sits level.
                So I'm almost at the stage of seeing where I'm at per the instructions. So far it's all been remedial work.
                Thanks again.
                • The Smythe Meister
                  • Jan 2019
                  • 6248
                  #23
                  Some lovely repair work and scratchduggery there Jim,.
                  Gotta admire your patience too:thumb2:.
                  It's coming along excellently so far.
                    • 22770
                    #24
                    Something to really get your teeth into Jim, and some cracking work so far.
                    • JR
                      • May 2015
                      • 18273
                      #25
                      Great work Jim, esp using a jig like that. The pewter work on that cylinder takes it to another level.
                      Keep it going.:thumb2::thumb2::thumb2:
                      • Allen Dewire
                        • 4741
                        • Allen
                        • Bamberg
                        #26
                        Wow Jigs!!! I just caught up and this looks to be a kit that's right up your alley. I know you love a challenge Jim, and I am very sure you will do the kit Justice...I too, have never seen or heard of a kit that uses string for the spokes. An interesting concept. Drive on Sir!!!...
                        That's why we call him Jigs, Dude 2...............He has other nicknames too..........
                        Allen
                        • colin m
                          • 8755
                          • Colin
                          • Stafford, UK
                          #27
                          This doesn't look like a build, more of a restoration - just like the real thing.
                            • 15709
                            Thanks so much for your posts. Always good to have support but especially appreciated when a kit has "issues" :smiling:
                            The chrome plated sprue has been stripped of it's finish in bleach. I don't like using the chrome finished parts for a few reasons. Firstly the chrome is often quite thick and obscures detail. Secondly it looks false, in my opinion, when used on a model and perhaps the main downside is that if any sanding of seam lines etc is needed it's virtually impossible to touch up neatly.
                            The engine requires some wiring and I have bought some wire which should be suitable. Thanks for earlier suggestions :thumb2:
                            • wotan
                              • May 2018
                              • 1150
                              #29
                              Fascinating stuff Jim and bravo for the patience to restore this one. Great stuff.
                                • 15709
                                Very little to show although time has been spent. Been over to my daughter's and the missus has dragged me off Christmas shopping a couple of times.
                                All I've really done is clean up parts and in some cases build small subassemblies.
                                First of the tiny missing parts scratched.
                                A bit early but Happy Christmas to you all.
