Revell Packard
  • johnm93
    • May 2016
    • 71
    Revell Packard
    Bought for ten quid from Avicraft in Bromley - a proper old Aladdin's cave....
    Going to build it OOB unless I change my mind...
  • johnm93
    • May 2016
    • 71
    It looks like all the parts are there - still in the bag.
    No indication of a scale, but it looks bigger than 1/48th, smaller than 1/35th...
    • Tworrs
      • Jan 2022
      • 1979
      • Garry
      • New Zealand
      This will be interesting.
        • 15653
        These old kits (1950s?) of old cars take a bit of work but can build into great models. It will be an interesting build to follow.
        • Steve-the-Duck
          • Jul 2020
          • 1731
          • Chris
          • Medway Towns
          The Revell Highway Pioneers kits are usually quoted as 1/32, and they do indeed come from the 1950s. Never having held one, and compared it to, say, Airfix, Matchbox, or Pyro 1/32 kits, who can say?
          Well, someone on here will know!
          Apparently, after a quick search of teh intrawebs, there was a Dapol series called Highway Pioneers too, but they had figures?
          • johnm93
            • May 2016
            • 71
            The destructions have a date of 1959 on them, so a kit made before most of us were born...?
              No No No - Like a lot of members - I have a few more years than that! I suspect that the model is earlier than '59 - more like '54 - it's supposed to be 1/32 - and it maybe originally from Merit, or Hudson Miniatures, so it is actually older than me!
              • johnm93
                • May 2016
                • 71
                The main 'cab' put together, black inside and the seat brown. The parts stick where they touch, with some gaps and sink holes...
                • johnm93
                  • May 2016
                  • 71
                  Two assemblies resting in their intended position.
                  Time to apply some filler to the 'cab'.
                    • 15653
                    Off to a good start. The fit on these old kits is often a bit iffy. Just needs patience, a lot of fettling and dry fitting and a bucket of filler :smiling:
                    • johnm93
                      • May 2016
                      • 71
                      Fill, sand, repeat, prime, sand ...etc...
                      • johnm93
                        • May 2016
                        • 71
                        Initial colours laid on to a few parts. The instructions call for 'Brown', 'Black', 'Yellow' etc
                        The primer and brown are Tamiya rattle can colours.
                        The seat and the yellow are acrylics via a hairy stick....
                        • johnm93
                          • May 2016
                          • 71
                          More of the major sub-assemblies resting loosely in place.
                          The fit of the suspension units is precarious - very little gluing surface...
                          The gold colour called for in the instructions is Tamiya rattle can - not sure how I am going to finish the radiator grille...
                          • johnm93
                            • May 2016
                            • 71
                            The carriage section has the final 'brown' sprayed on and the bonnet has the third coat of very thin 'yellow' brushed on.
                            Attempt one of making the radiator look realistic has, so far, the 'gold' sprayed on and some black brushed into the grille - I now need to work out how to highlight the grid part with silver...
                            Not sure how to do this yet.....
                              • 15653
                              Coming on very well. Dry fitting and patience, as you're doing, is the way forward.
                              The "grid" part of the radiator is raised, I assume, so a couple of ways to go about silvering it.
                              Firstly dry brush with silver to pick out the mesh. A second way would be paint overall silver, a couple of coats, then paint overall black. Now very gently sand back the raised mesh to reveal the underlying silver.
