Thanks Andy, i'm trying ... so the missis says anyway
Soooo ... i thought i'd do a base, and also thought that it might offer a few tips i've come across on here if i did a sort of step-by-step.
made a base out of balsa, laid polystyrene sheet over it and 1200 wet and dry paper over that to form the road then melted the edges of the poly sheet to get a natural edge.
When dry take out and paint, light grey, then darker grey whilst the lights still wet to blend, then a darkish green to give a little moss effect, after dry wet areas with PVA and add some mixed scatter to for moss and lichen growing on the wall.
Make up the floor of the base with balsa to get a ditch effect, paint to get a colour base and add the gravel, mud and dirt (of your choice) glue the wall in situ so the dirt fills the cracks and looks natural
Add the white lines and dirty the road up a little, this is quite easy as all you need to do it tip dirt on and the fine dust will settle in the wet and dry ... just brush off what you dont need so it looks ok.
I've some how missed this, sorry Colin, love the GTO and the wheels suit it, I also agree, the Green is so much better looking than boring Red...
Thank you for the dio tutorial also, I promise I will give this one a go some day soon, seeing as I prefer making the car models at the moment it would be great for taking photos with them on it...
I've completed it in my representation of the car participating in the 1999 Goodwood festival, indicated by the number 7.
Some ideas i tried (some worked some didnt so well).....
Pulled the wheels in a little so there was more clearence to the rear wing
Decals were improvised a little as i didn't want to strive to be too anal or rivet counting.
The colour isn't spot on, but i think i like this slightly darker peagreen myself.
The numbers and panels were attempted to look like they were peel-on/peel-off as in real life, think i managed it apart from the white on the rear which looks a little shabby close up.
All in all i've enjoyed this and might even do another car at some stage.
