So I'm 70% done, but I managed to take a picture after every instruction stage, I plan on throwing these into a video when I'm done
I'm fairly enjoying the kit, fits together perfectly, dry fitting helped a lot, my main regret was not painting as I went along, this mistake has made me decide to glue the bonnet down instead of allowing it to be lifted open or closed like the kit allows, silly me ):
So the first few stages involved assembling the engine and the start of the axle
[ATTACH]56241.vB[/ATTACH][ATTACH]56242.vB[/ATTACH][ATTACH]56243.vB[/ATTACH][ATTACH]56244.vB[/ATTACH]
At this point, the axle etc was added and then fitted to the chassis , at this point the kit allows you to set the angle of the wheels, so I turned mine to the right slightly in an attempt to make the kit look more dynamic in the end, I don't believe you have to glue these parts but once they were in place I decided to
[ATTACH]56245.vB[/ATTACH][ATTACH]56246.vB[/ATTACH][ATTACH]56247.vB[/ATTACH][ATTACH]56248.vB[/ATTACH]
At this point I couldn't resit fitting the body onto it to see what it was starting to look like, being my first proper kit, I was personally impressed with how realistic the parts look
[ATTACH]56249.vB[/ATTACH]
More parts were added to the engine bay, along with the rear axle and exhaust
[ATTACH]56257.vB[/ATTACH][ATTACH]56258.vB[/ATTACH][ATTACH]56259.vB[/ATTACH][ATTACH]56260.vB[/ATTACH]
[ATTACH]56261.vB[/ATTACH][ATTACH]56262.vB[/ATTACH]
I then decided to use the racing style wheels that come in the kit over the standard Mini wheels
[ATTACH]56263.vB[/ATTACH]
I then started on the interior, with pedals, gear stick and handbrake, dash, seats and steering wheel, which I glued in place rotated to the right a little to match the wheels. The roll cage and some further parts were added to the engine before another test fit before I realised it would actually need painted :P
[ATTACH]56264.vB[/ATTACH][ATTACH]56265.vB[/ATTACH][ATTACH]56266.vB[/ATTACH][ATTACH]56267.vB[/ATTACH]
[ATTACH]56268.vB[/ATTACH][ATTACH]56269.vB[/ATTACH][ATTACH]56270.vB[/ATTACH][ATTACH]56271.vB[/ATTACH]
So I sprayed a fey layers of red on with the airbrush, attempting to highlight in a few places like the edges of the bucket seat and the centres on the underside, unfortunately it didn't work out that well for me, but after the glass I was pretty happy with the tone of the red in the end, but unfortunately adding the windows I smeared the glue with my finger by accident on the driver door ): Also when I was glueing the window in, it slipped on me and using plastic glue of course the paint had melted into the window... D:
[ATTACH]56272.vB[/ATTACH][ATTACH]56273.vB[/ATTACH][ATTACH]56274.vB[/ATTACH][ATTACH]56275.vB[/ATTACH]
[ATTACH]56276.vB[/ATTACH][ATTACH]56277.vB[/ATTACH][ATTACH]56278.vB[/ATTACH][ATTACH]56279.vB[/ATTACH]
After a few more assembly stages mainly the bonnet hinge and the door cards, but afterwards these were removed alongside the windows again, disaster move on my part, but I just wasn't confident enough to paint the window frames without getting it on the window
[ATTACH]56280.vB[/ATTACH][ATTACH]56281.vB[/ATTACH][ATTACH]56282.vB[/ATTACH][ATTACH]56283.vB[/ATTACH]
So that's where is it is now, I'm fairly enjoying it so far and has definitely been a learning experience for me, C&C will be definately appreciated, and any tips for the windows for future projects will be really appreciated :P
Cheers everyne
[ATTACH]58323.IPB[/ATTACH]
[ATTACH]58324.IPB[/ATTACH]
[ATTACH]58325.IPB[/ATTACH]
[ATTACH]58326.IPB[/ATTACH]
[ATTACH]58327.IPB[/ATTACH]
[ATTACH]58328.IPB[/ATTACH]
[ATTACH]58329.IPB[/ATTACH]
[ATTACH]58330.IPB[/ATTACH]
[ATTACH]58331.IPB[/ATTACH]
[ATTACH]58339.IPB[/ATTACH]
[ATTACH]58340.IPB[/ATTACH]
[ATTACH]58341.IPB[/ATTACH]
[ATTACH]58342.IPB[/ATTACH]
[ATTACH]58343.IPB[/ATTACH]
[ATTACH]58344.IPB[/ATTACH]
[ATTACH]58345.IPB[/ATTACH]
[ATTACH]58346.IPB[/ATTACH]
[ATTACH]58347.IPB[/ATTACH]
[ATTACH]58348.IPB[/ATTACH]
[ATTACH]58349.IPB[/ATTACH]
[ATTACH]58350.IPB[/ATTACH]
[ATTACH]58351.IPB[/ATTACH]
[ATTACH]58352.IPB[/ATTACH]
[ATTACH]58353.IPB[/ATTACH]
[ATTACH]58354.IPB[/ATTACH]
[ATTACH]58355.IPB[/ATTACH]
[ATTACH]58356.IPB[/ATTACH]
[ATTACH]58357.IPB[/ATTACH]
[ATTACH]58358.IPB[/ATTACH]
[ATTACH]58359.IPB[/ATTACH]
[ATTACH]58360.IPB[/ATTACH]
[ATTACH]58361.IPB[/ATTACH]
[ATTACH]58362.IPB[/ATTACH]
[ATTACH]58363.IPB[/ATTACH]
[ATTACH]58364.IPB[/ATTACH]
[ATTACH]58365.IPB[/ATTACH]
Cheers everyne
