1949 Mercury custom coupe 1/25 Revell
    Having done the 'Woody' last year figured it was time to do the Merc ,first up cleaning the frame up and replacing the coil springs
    I used some copper wire coiled around some sprue for the front coils
    I used ca to glue them in the retainer cups and trimmed them to the right height
    This nasty bit of frame support is the same molding as the Woody I did last year and its a bear to get in place and keep the holes lined up while the glue sets. I learned from doing the Woody to start glueing from the rear and let each section set before going to the next. I rushed this on the Woody and wound up spending a lot of time filling and cleaning up the misalignment,totally my fault.
    This time around the patience has paid off and no filler will be needed just a little fine filing and sanding. Started working on the mill and going to keep it basic out of box except the exhaust manifolds,and some detailing such as plug wires and a few fluid lines.
    Before I can finish the Mill the chrome needed to be stripped off . I use straight bleach and it really works fast,the stuff literally dissapears before your eyes.
    now just pour the bleach back into the bottle and sneak it back in the laundry room and the Missus never missed it!
    thats a cool idea for the chrome stuff,thnx trey
    mobear
    • yak face
      • Jun 2009
      • 13840
      • Tony
      MMMM! a chopped ,slammed merc , beautiful! What colour is it going to be trey ? Ill be following this closely , for me the urge to do a car is getting stronger and stronger ! cheers tony
        • 18266
        Hmm me like.
        I'll have mine in flat titanium grey with with a nice subtle pinstripe flame in the same colour, just in gloss. Maybe over a cracked gold leaf, for a bit of depth.....
        Failing that, black.
        • flyjoe180
          • Jan 2012
          • 12390
          • Joe
          • Earth
          Great tip using bleach to remove the chrome Trey, cheers.
            I like this build Trey!! And great tip and idea to use the bleach!!
            Thanks. Polux
              A new one to look forward to eh Trey. ill be watching this one come alive.
              Andy
                Ole thanx!
                Tony .I'm thinking either a hot lime green metallic pearl,or satin black with 'real' looking flames
                Ian yes that sounds really tight too ,taking it in to consideration for sure thanx
                Joe,Polux and Andy thanx !
                I've gotten the brake lines run and the rear axle assembly in place
                then some semi gloss black
                • michaelm
                  • Dec 2011
                  • 437
                  Black with flames!!!!
                  Yes please. M
                    • 22770
                    A very nice start Trey will watch what you do with this I fancy doing a car also
                    • yak face
                      • Jun 2009
                      • 13840
                      • Tony
                      Lime green metallic pearl , with alu moon discs and whitewalls please . Oh and a side order of fuzzy dice , cheers tony
                        I've sprayed the chasis bottom and sanded the body with 400 grit to get rid of some fine mold seams
                        Shot the primer on and started scratching the exhaust
                        Tony I like that idea too,thanks. I'm thinking a theme paint scheme from the Scorpions 'Blackout' song,its been stuck in my head ever since I started this . Maybe done in satin black with pearl lime green mettalic accents or even 2-tone.
                          I've gotten the interior basically done ,the dash detailing and some fiddly bits aside
                          • flyjoe180
                            • Jan 2012
                            • 12390
                            • Joe
                            • Earth
                            Very clean and tidy Trey, don't you just love those old interior colours!
                              Thanks Joe ,keeping it basic inside for sure.I've got the mill basically finished minus some plumbing and wiring details. The exhaust pipes did'nt go quite as planned but its passable.
