Tamiya 1:24 Ferrari F40
    This was my second car. The F40 is my all time favorite car. I thought I should have waited until my skills had developed but I really couldnt wait to get up close and personal with the best car ever made....
    The black line around the body was tremendously tricky and was the worse part of the model...
    [ATTACH]58875.vB[/ATTACH][ATTACH]58876.vB[/ATTACH][ATTACH]58877.vB[/ATTACH][ATTACH]58878.vB[/ATTACH]
    [ATTACH]60697.IPB[/ATTACH]
    [ATTACH]60698.IPB[/ATTACH]
    [ATTACH]60699.IPB[/ATTACH]
    [ATTACH]60700.IPB[/ATTACH]
    • 22770
    I can see why your proud of this one Jim looks like a very nice build well done
    • Adrian "Marvel" Reynolds
      • Apr 2012
      • 3008
      Also a very nice build
      Adrian
        Thank you. Ordered a Honda NSX (Tamiya) yesterday. Posts to follow...
        • bluriusz
          • May 2012
          • 400
          Nice build, but you should apply some wash on it. Lines on the body are barely visible.
          I'd recommend to do the pictures in the daylight as well, that will decrease noise effect and add a lot to your presentation.
          Good luck with NSX!
          Regards,
          Bart.
            Thanks for the tip.
            Pardon my ignorance but I don't know what 'wash' is? - unless you mean it just needs a clean - which I'm sure you don't!
            I will be sure to get the NSX washed and pictured in daylight when it is done!....
            PS. can you recommend a tool to shade panel gaps in black? I saw some dude on YouTube do this to an F40 and it was really effective!
              • 18266
              A wash is just a thinned paint or pigment that is used to bring out detail and panel lines. Much as you have self pondered in your PS. its not a secret tool or magical trick just good old paint.
              Good panel lines on a car can be done with a very thin, water like thin paint and a very fine brush. Just load the brush and place the tip carefully in the panel line. The wash will wick out of the brush and run up the line.
              The model will need a gloss finish for this to work.
              If you paint with Acrylics, an oil paint wash is best. If you paint with enamels, a water based wash will be needed, as the solvent for the oil/enamel paint will effect the body colour paint.
              Nice car by the way, even though I don't like Ferraries, well most of them. I like a Dino.
                Sweet looking F-40 Jim
                  forza ferrari
