My Lambo Countach 5000 Build....
  • takeslousyphotos
    • Apr 2013
    • 3900
    My Lambo Countach 5000 QUATROVALVOLE Build.... Fujimi 1/24
    I bought this on evilbay.......... Supposedly only a few bits assembled / painted.
    Well I made a start. Although not the start I was expecting. When I went through the kit I found a small ziplock bag with some engine parts that had been assembled..........and assembled quite badly. However, and I have no idea why but whoever had done it had:
    A. Not trimmed or cleaned any of the parts up
    B. Not given any thought to how different parts could be painted in different colours
    and.........
    C. Had not used Poly Cement. I have no idea quite what had been used but it was brown and quite brittle????
    Anyway. Luckily everything came apart relatively easily but cleaning off whatever the adhesive was took a while. But finally I think I'm back where it should have started. I've cleaned everything up and "dry fit" tested all the components that had been put together. So tomorrow I can start afresh and paint some of them.
    I'll post some piccies as I go.
    Peter
  • flyjoe180
    • Jan 2012
    • 12390
    • Joe
    • Earth
    Sharp looking car Peter, look forward to the build.
      Ah the evils of pre started kits.
      Good luck, looking forward to seeing a few photos
      • takeslousyphotos
        • Apr 2013
        • 3900
        Originally posted by \
        Ah the evils of pre started kits.Good luck, looking forward to seeing a few photos
        Yes. I know we all have different skill levels......... and I know mine are sadly lacking in many many things but that really was beyond my understanding.
        I'm just glad they came apart ok.
        Peter
        • Andy2035
          • Aug 2011
          • 730
          Hi Peter,
          This was and still is one of my dream cars, looking forward to watching this one...:biggthumpup:
          Their the only kits I can afford these days, some aren't too bad and then others are just a little too beyond so they become part supplies...
          Andy...
          • takeslousyphotos
            • Apr 2013
            • 3900
            Hi Peter,This was and still is one of my dream cars, looking forward to watching this one...:biggthumpup:
            Andy...
            Maybe this one will be a waste of time........ I'll see as we go. If it turns out to be a mission beacause nothing fits properly then it'll end up in the bin. It only cost me £8.00 so not much to lose other than my time invested in it.
            But I will give it my best shot.
            Peter
            Peter
            • Andy2035
              • Aug 2011
              • 730
              Maybe this one will be a waste of time........ I'll see as we go. If it turns out to be a mission beacause nothing fits properly then it'll end up in the bin. It only cost me £8.00 so not much to lose other than my time invested in it.But I will give it my best shot.
              Peter
              Peter
              Hi Peter,
              Don't just bin it, keep it and use it for spares etc, you could even turn it into a scrap car in a diorama but, don't just bin it...
              Andy...
              • takeslousyphotos
                • Apr 2013
                • 3900
                Well we have an engine and gearbox ............. I'm working on some HT Leads (I've destroyed an old computer lead) ......... But apart from those it's done. Chassis and suspension next.
                .............. I really am rubbish with a camera.
                Peter
                  I love the Countach. Lambo at their most stupid
                  • takeslousyphotos
                    • Apr 2013
                    • 3900
                    Hi All,
                    Bit of a crisis going on here ........ As you know this was a part started kit. Having salvaged the engine (I'm really quite pleased with the result. I've moved on to chassis and suspension ........ and here's the "rub" as they say. Mr "part build has painted some of the components on the sprues, not many but enough. He has decided to paint them "Gloss Black" when they should be "Matt Black". So, starting with the front bulkhead I flatted it down and started painting. It's not very big so I thought I'd brush it and, the paint just wouldn't go on just like there was a film of grease on it. So I cleaned it off with some IPA and a bit of soapy water let it dry and tried again. Same result.............. So I thought I'd spray it and while I'm at it I'd do the main chassis as well. Now bearing in mind most of these components have intricate mouldings so I cant get to all the corners with abrasive. Anyway, I sprayed them and the paint has just crazed. I'm using acrylic paint so I would have thought it wouldn't react like that.......... As I have no idea what "Mr Part Build" has used I'm sort of stuck..............I don't want to give up on it because so far it's been a great kit to build.
                    Any thoughts or ideas would be most welcome.
                    Peter
                      Peter
                      Great wok on that engine, very nice indeed.
                      For your paint problem maybe an overspray of some enamel paint, just a thought
                      • yak face
                        • Jun 2009
                        • 13836
                        • Tony
                        At first i would have said that he had used enamel paint and maybe that was why the acrylic you brushed on didnt stick , but then you said the acrylic aerosol crazed the paint i'm not so sure now. If it was me i would be tempted to get some Fairy power spray and strip everything back to the plastic and start again , cheers tony
                        • takeslousyphotos
                          • Apr 2013
                          • 3900
                          Well I've made a bit of progress ................ Front Suspension is done, Front Bulkhead is in, Engine is in and the rear fenders are fitted.
                          The rear fender on the left side was a bitch. The moulding where it mounts on the chassis was twisted. I tried warming it up and straightening it but it was having none of it. So I ended up chopping it up and rebuilding the "trellis" with some sprue............... It aint perfect but it's pretty close, and most of it's almost hidden anyhow.
                          There is some more detail to go in the engine bay, rear suspension and then cockpit.............. After that lot (and there really is a lot to this Fujimi kit)...... I'll attack the bodywork.
                          Peter
                            your acrylic is waterbased? and the paint on the model is older oil based enamel?
                            sounds like it needs a stripping.
                            • takeslousyphotos
                              • Apr 2013
                              • 3900
                              your acrylic is waterbased? and the paint on the model is older oil based enamel?sounds like it needs a stripping.
                              What can I use to strip it ???
                              Peter
