Ok started on the pointy end, had an issue with this bit had to remove the H/T leads, when i test fitted the bonnet it would not close down all the way.
Once removed i had a perfect fit, will try to fit new ones but a little smaller but its going to be a bit fiddly with the engine fitted, battery connected & fuel pip to carbs installed.
Hope to fit wheel hubs with flexy hose & brake pips today.
