Scratchbuilt 1:34 BMW M3 GTR
    Hi everyone, this is my first post here. just wanted to share this model i'm currently working on. any suggestions? will update as soon as there is any. cheers!
    [ATTACH]74420.IPB[/ATTACH]
    [ATTACH]74421.IPB[/ATTACH]
    [ATTACH]74422.IPB[/ATTACH]
    [ATTACH]74423.IPB[/ATTACH]
    [ATTACH]74424.IPB[/ATTACH]
    [ATTACH]74425.IPB[/ATTACH]
    [ATTACH]74426.IPB[/ATTACH]
    [ATTACH]74427.IPB[/ATTACH]
    [ATTACH]74428.IPB[/ATTACH]
    [ATTACH]74429.IPB[/ATTACH]
    [ATTACH]74430.IPB[/ATTACH]
    [ATTACH]74431.IPB[/ATTACH]
    Coming together nicely!
      Just found this one, it's looking very good.
      Anymore photo's?
      • eddiesolo
        • Jul 2013
        • 11193
        Nice plasticard build, looks he hasn't been on in a while.
        Si
          Originally posted by \
          Just found this one, it's looking very good.Anymore photo's?
          thank you. The above pics cover up the progress so far pretty well, i'll post new ones when the work resumes.
          plastic is not used anywhere, paper (standard A4 sheets) and cardboard form most of the raw materials as these pics will show
          [ATTACH]74857.IPB[/ATTACH]
          [ATTACH]74858.IPB[/ATTACH]
            I think card modelling is fascinating, especially when you are making complex curves as in a car body. This is looking very interesting and coming along very well. Are you using a plan or pictures for the guidance?
            • eddiesolo
              • Jul 2013
              • 11193
              thank you. The above pics cover up the progress so far pretty well, i'll post new ones when the work resumes.plastic is not used anywhere, paper (standard A4 sheets) and cardboard form most of the raw materials as these pics will show
              Then I stand corrected, apologies for that, outstanding card work. I have enough issues working on preformed plastic never mind even attempting anything is card.
              Si
                It's looking good so far, especially seeing as it's made of card. Will the indicators work? :P
                  yes, first i study some pictures and then draft a blueprint with associated dimensions
                  not in this one, maybe in the next build
                    Hi again! completed the engine assembly
                    1. cylinder head badges ready to be painted and mounted
                    2. the rear view of the engine, showing no flywheel, which will be mounted once the gearbox is ready
                    3. writing "BMW Power" within the 10mm space was a bit tricky
                    4. a few more bits for the cylinder head
                    5. intake header under construction
                    6. a cavity had to be cut from the hood to accommodate the complete engine
                    7. intake header near completion
                    8. header completed
                    9. mounted on the engine
                    10. alternator and other auxiliary pulleys mounted
                    11. cam-belt mounted
                    12. The complete P60 B40 powerplant
                    more updates underway. Thanks for stopping by and watching.....cheers!
                    [ATTACH]75752.IPB[/ATTACH]
                    [ATTACH]75753.IPB[/ATTACH]
                    [ATTACH]75754.IPB[/ATTACH]
                    [ATTACH]75755.IPB[/ATTACH]
                    [ATTACH]75756.IPB[/ATTACH]
                    [ATTACH]75757.IPB[/ATTACH]
                    [ATTACH]75758.IPB[/ATTACH]
                    [ATTACH]75759.IPB[/ATTACH]
                    [ATTACH]75760.IPB[/ATTACH]
                    [ATTACH]75761.IPB[/ATTACH]
                    [ATTACH]75762.IPB[/ATTACH]
                    [ATTACH]75763.IPB[/ATTACH]
                      hi again, finished front and rear suspension systems, and fitted the powertrain into chassis[ATTACH]76285.IPB[/ATTACH]
                      [ATTACH]76286.IPB[/ATTACH]
                      [ATTACH]76287.IPB[/ATTACH]
                      [ATTACH]76288.IPB[/ATTACH]
                      [ATTACH]76289.IPB[/ATTACH]
                      [ATTACH]76290.IPB[/ATTACH]
                      [ATTACH]76291.IPB[/ATTACH]
                      [ATTACH]76292.IPB[/ATTACH]
                      [ATTACH]76293.IPB[/ATTACH]
                      [ATTACH]76294.IPB[/ATTACH]
                      [ATTACH]76295.IPB[/ATTACH]
                      [ATTACH]76296.IPB[/ATTACH]
                      [ATTACH]76297.IPB[/ATTACH]
                      [ATTACH]76298.IPB[/ATTACH]
                      [ATTACH]76299.IPB[/ATTACH]
                      [ATTACH]76300.IPB[/ATTACH]
                      [ATTACH]76301.IPB[/ATTACH]
                      [ATTACH]76302.IPB[/ATTACH]
                      that's it for now, hoping to finish it in next 2-3 days, thanks for watching!
                        hello! the model is completed
                        [ATTACH]76791.IPB[/ATTACH]
                        [ATTACH]76792.IPB[/ATTACH]
                        [ATTACH]76793.IPB[/ATTACH]
                        [ATTACH]76794.IPB[/ATTACH]
                        [ATTACH]76795.IPB[/ATTACH]
                        [ATTACH]76796.IPB[/ATTACH]
                        [ATTACH]76797.IPB[/ATTACH]
                        [ATTACH]76798.IPB[/ATTACH]
                        [ATTACH]76799.IPB[/ATTACH]
                        [ATTACH]76800.IPB[/ATTACH]
                        [ATTACH]76801.IPB[/ATTACH]
                        [ATTACH]76802.IPB[/ATTACH]
                        [ATTACH]76803.IPB[/ATTACH]
                        [ATTACH]76804.IPB[/ATTACH]
                        [ATTACH]76805.IPB[/ATTACH]
                        [ATTACH]76806.IPB[/ATTACH]
                        [ATTACH]76807.IPB[/ATTACH]
                        [ATTACH]76808.IPB[/ATTACH]
                        [ATTACH]76809.IPB[/ATTACH]
                        [ATTACH]76810.IPB[/ATTACH]
                          [ATTACH]76811.IPB[/ATTACH]
                          [ATTACH]76812.IPB[/ATTACH]
                          [ATTACH]76813.IPB[/ATTACH]
                          [ATTACH]76814.IPB[/ATTACH]
                          [ATTACH]76815.IPB[/ATTACH]
                          [ATTACH]76816.IPB[/ATTACH]
                          together with force india VJM03 built 3 years ago
                          [ATTACH]76817.IPB[/ATTACH]
                          [ATTACH]76818.IPB[/ATTACH]
                          that's it for now until my next project, which is going to be an f1 car. thanks for watching
                          • eddiesolo
                            • Jul 2013
                            • 11193
                            Wonderful, and all made out of card. Superb skill in making those pieces and putting it all together.
                            Si
                              mad man springs to mind,these are fantastically awesome mate
