Christine completed
    So here is where I am on Christine so far, I think I have saved the spray job.
    thanks for all your good advice.
    • eddiesolo
      • Jul 2013
      • 11193
      #17
      Looking good there, so, assembly is next.
      Si
        doing that as we speak.
        • Lee W
          • Feb 2014
          • 4654
          • Lee
          • Sherborne
          #19
          I'm liking it...
          Lee
            Originally posted by \
            Another tip is to sand in one direction, from back to front and straight along the flanks, do not use a swirl motion or you will never get them out and they are really difficult to cover.
            Si
            My trial pack of micromesh says to sand in straight lines ("first sanding"). Then with a finer grit size sand at right angles to the first sanding ("second sanding"). This is to allow you to see when the signs of the first sanding have been sanded away. Repeat with a finer grit, again at right angles, that is, in the same direction as the first sanding ("third sanding), and so on. If this is the final gloss coat, there will be only very fine scratches left which can be removed with a polishing cream. I have tried this successfully on Tamiya Lacquer (its solvent it cellulose lacquer) which seems to be quite tough, and tougher than others, for example Mr. Hobby's Gloss Black acrylic which can quickly go through to the primer..
            This sanding plan is not so easy on curved surfaces where it is sometimes difficult to sand in both directions.
              The seats and interiors looking good so far.
                Bring it on dude, looking good so far keep up the good work.
                  here is the next exciting installment
                    A little update
                    • flyjoe180
                      • Jan 2012
                      • 12400
                      • Joe
                      • Earth
                      #25
                      Wow, that looks really good.
                      • Lee W
                        • Feb 2014
                        • 4654
                        • Lee
                        • Sherborne
                        #26
                        You did say Christine and not Starsky and Hutch...didn't you? :P
                        Good job fella
                        Lee
                          Well your lucky I was sorely tempted to put a union flag on the roof
                          • john i am
                            • Apr 2012
                            • 4019
                            #28
                            Great job your doing on Christine looking forward to the next installment cheers John
                            • Lee W
                              • Feb 2014
                              • 4654
                              • Lee
                              • Sherborne
                              #29
                              Now that would have been funny...The General Christine
                              Lee
                                Yes maybe for a future project
