Christine completed
    I like it!!
    Keep up the good work!
      well this is the kit built now to start on the dio any ideas how i am going to crumple the wings up.
      I did think about cutting them off and trying to scratch build some bent up ones but not sure my skills are up to that, then i thought about taking a blow torch to her and bending her that way but there is a lot of plastic on the front there and i think that would be to risky to recover from should it all go wrong.
      • Lee W
        • Feb 2014
        • 4654
        • Lee
        • Sherborne
        #33
        How about sanding them back different angles to give the crumpled illusion or like you said, heat it but not to the extreme and bending slightlyo_O
        Lee
        • Lee W
          • Feb 2014
          • 4654
          • Lee
          • Sherborne
          #34
          Bit late but she does look sweet!
          Lee
          • eddiesolo
            • Jul 2013
            • 11193
            #35
            Firstly, I would rethink destroying her, she is a lovely looking model and you have made a superb job of her. But, if you're adamant that she is to be crushed, then only thing I can see is, as Lee points out, to gently heat the front end and then crush-heat it up-turn upside down and then press the front onto a hard surface-repeat as often as needed. Just do not overheat or you will melt the plastic too much-you could try a hair-dryer on full power and try that.
            Si
              Hi all thanks for your suggestions, I did buy her with the intention of doing a dio of the filming of her crushing moochie, I wasn't going to put her all the way in just starting to work her way to moochie. I have had another idea I could cut the walls away where she is pushing her way through then put filler on the wings to make it look like they have buckled from forcing her way into the loading bay.
              • eddiesolo
                • Jul 2013
                • 11193
                #37
                You could try, gently heating the side panels, from bumper edges and then pushing in gently to recreate the rippled effect of the steel against the wall. Problem with filler on the wings is that you are adding to car, so making the nose section look distorted and fat...if that makes sense.
                Si
                  Hi guys I have never deliberately destroyed a model before so before I start on this one I want to be sure I've got it right, so I've drawn up a plan to make sure for one thing the base is big enough but also it gives me something to work from. So here is the plan
                  the bull Dozer I dont know weather I have put it far enough back I have put a Girder on the front of it as i think they must have done something like this to keep it out of the frame in close up shots from the back, can you guys think of something I have missed, I wont be doing anything to Christine till nearer the time she will go on the dio so she will be ok for quite a while.
                    Stunning as she is
                    But if you must there is nothing like a fire
                      Great modelling and subject matter As your clearly a fan, in the bulldozer scenes was it a MK2 Cortina that Christine smashes into first?
                      Regards, Frame.
                        There seems to be some confusion here I am not doing the Bulldozer scene I am doing the (FILMING)of the scene where Moochie gets squished in which they used a Bulldozer to push Christine into the loading bay as no car could do that under its own power it would get so far the the wheels would start spinning and that would be as far as it got.
                          Hi all I have made a start on the dio and it is going to be a long slog. I am making the walls of the loading bay out of foam board and I tried printing the bricks off but it is almost impossible to get the scale right and anyway it just doesn't look right as there the mortar line is smooth, so I thought I would use foam board and draw the scale bricks on it as, if you press reasonably hard you can leave an impression which will hopefully look more like a mortar line. Well that's a job I wish I hadn't started(still hopefully it will be worth the effort) .
                          Incidentally we know the film is full of mistakes, like the bit I am doing where he could have quite easily got away by jumping on Christines bonnet and running over the top of her, well I have thought of another flaw it's supposed to be a loading bay, usually an arctic can fit in a loading bay, but if Christine can't fit in there that means even a van can't, that makes it a pretty useless loading bay.
                            Here are some pics of the 1\24 scale wall with the mortar colour painted I know it looks orangy but trust me its not, dont know what happens with my camera sometimes.
                            was hoping that the last pic would show the bricks effect but it shows a lot better on the next one.
                            I think the effect will be better when i paint the bricks, this has taken me 2 days so far and i recon I will need at least 1 more to finish all the brickwork.
                              Im very familiar with the scene you are going for,I just asked as you know the film if you know if it was a Cortina in the ending with the Cat.
                              Cheers,Frame.
                              • Lee W
                                • Feb 2014
                                • 4654
                                • Lee
                                • Sherborne
                                #45
                                This build gets more involved and better and better :P
                                Lee
