Christine completed
    Oh well back to the drawing board apparently thats an 80s video camera it should be a panaflex 35mm camera like the one Si described with the 2 reels on the top and the square lens glare attatchment been shown a pic of John Carpenter on the set of Christine with the camera in the background, its a huge camera almost as big as Carpenter himself. thats where I have been searching with the wrong phrases, I've been searching Stephen kings Christine, I should have been searching John Carpenters Christine.
    • eddiesolo
      • Jul 2013
      • 11193
      #62
      Well, how do you know that a video camera wasn't used for setting up shots and for filming dailies?
      Si
        So you think I could still use it Si the panaflex is huge and complex not sure how I am going to scale that can't find a photo with a hand grip to scale it by, if I can find out the diameter of the lens maybe I could use that, or I will just have to make a rough guesstimate.
        • eddiesolo
          • Jul 2013
          • 11193
          #64
          You could use it no problem.
          Here is a piccie of a panaflex in use with guy to give scale. http://image.toutlecine.com/photos/r/u/m/rumeur-court-2005-tou--02-g.jpg
          Try this website, got some good piccies that may help you. http://www.cinematographers.nl/CAMERAS2.html
          Si
            Thanks Si great for scaling (its huge ain't it) you have been extremely helpful, I am really greatfull
            • eddiesolo
              • Jul 2013
              • 11193
              #66
              No problems mate, cannot wait to see your finished dio.
              Si
                Well back from hols and I have ordered 50 assorted 1/24 figures off ebay, I am sure I should be able to fashion a Moochie out of them and a film crew. I have also ordered a 1/16 bulldozer (can't find a 1/24 cheap enough) but it's a simple Cat bulldozer and I think I can cut it down to 1/24 (famous last words) but I am not paying 80 quid and 20. Odd quid postage. So........hopefully I will have everything I need to finish the dio (famous last words again).
                • eddiesolo
                  • Jul 2013
                  • 11193
                  #68
                  I am sure you will be able to do it...have faith...
                  Si
                    Hi all I have decided to get back to Christine and here is what i have so far
                    • monica
                      • Oct 2013
                      • 15169
                      #70
                      i do like the walls, nice colors to them,
                      • eddiesolo
                        • Jul 2013
                        • 11193
                        #71
                        Nice, very nice.
                        Si
                        • Lee W
                          • Feb 2014
                          • 4654
                          • Lee
                          • Sherborne
                          #72
                          I'm liking this Ken, come on mate, you can do this, like me (no doubt a few others as well, mojo is to-ing and fro-ing), we are all behind you
                          Lee
                            Nice pattern with the bricks bricks.
                              thanks all for the encouragement done a bit more on the stageing
                              this is what i am using for the TarMac
                              I have used the pva glue round the patches and the joins I am hoping it will look like the liquid tar they use to fill the joins on a TarMac road when painted black also i will be injecting pva under the sandpaper in a few places to make it uneven and i am going to try and create the wrinkle you get when the Tar cracks in the heat.
                              I did think about printing a Hershes bar ( Ithink thats what they are called) wrapper reducing it to 1\24 screwing it up with a bit of foil and chucking it in the loading bay against the end wall for some wind blown rubbish, will have to do some research on what type of junk food was avaliable then so I can add some to the dio.
                                Well the dozer has arrived and I think it's an Oops moment I chose it as it looked a simple cut up and reassemble as a 1\24 model but its a lot more detailed than i thought, and it is HUGE I put it on the dio just to see the effect and i wont get away with that scale.
                                as you can see it towers above everything, the way I see it I could cut the roof off the Cat and see if it looks like i can get away with that or i shorten the dio and sort of just show the shovel of the Cat and leave the rest to everyone's imagination, I am open to suggestions Guys and Gals, help !!! any suggestions at all will be welcome.
