1:16 AMT Chevy nomad (1955)
    The story so far in pics custom version.[ATTACH]80775.IPB[/ATTACH]
    [ATTACH]80776.IPB[/ATTACH]
    [ATTACH]80777.IPB[/ATTACH]
    [ATTACH]80778.IPB[/ATTACH]
    [ATTACH]80779.IPB[/ATTACH]
    [ATTACH]80780.IPB[/ATTACH]
  • Richi72
    • Sep 2013
    • 1100
    Nice one Rob,
    Cool car. Like the Blue metallic
    will keep an eye on this.
    Cheers Richi
    • ojays
      • Oct 2011
      • 1713
      Chop the roof, Chop the roof!!
      Gregg
      • PaulTRose
        • Jun 2013
        • 6460
        • Tattooine
        going to be big in that scale!
        stock or custom?
        Per Ardua
          Cool
          • flyjoe180
            • Jan 2012
            • 12390
            • Joe
            • Earth
            Love that blue colour. Nice work Rob, look forward to another super car result
              Painted the body yesterday just got it out of its pod (seed tray with lid) and I am over the moon sorry for poor pics I must buy a camera.
              [ATTACH]80995.IPB[/ATTACH]
              [ATTACH]80996.IPB[/ATTACH]
                I agree love the colour looking good
                • Alan 45
                  • Nov 2012
                  • 9833
                  That colour is great and it's a good start I'll keep an eye out for this
                    It will be a showy car!! I like it
                      My first attempt at HT leads did not go well at all the tubing absolutely refused to stick to the dizzy and after many attempts the glue was melting away the plastic until I abandoned all the modelling glue's and went and bought some super glue that bonds in less than 2 seconds ...... tested it on a sprue first just in case it turned the whole thing into a blob, it was perfect and job done see what you think any advice, comments or criticism is welcome without these we do not learn?
                      Rob.
                      [ATTACH]81171.IPB[/ATTACH]
                      [ATTACH]81172.IPB[/ATTACH]
                      [ATTACH]81173.IPB[/ATTACH]
                      [ATTACH]81174.IPB[/ATTACH]
                      [ATTACH]81175.IPB[/ATTACH]
                        Hi Rob outstanding work to date, the only criticsm i have is i think the HT leads are a little on the long side, i had the same problum with mine when it came to fit the engine in i could not close the bonnet as the leads were to high.
                        In the end i had to use coax wire to get the 90 deg bend from the dizzy. hope you dont mind the photo or the advice.
                        [ATTACH]81176.IPB[/ATTACH]
                        Looking forward to seeing more.
                          Originally posted by \
                          Hi Rob outstanding work to date, the only criticsm i have is i think the HT leads are a little on the long side, i had the same problum with mine when it came to fit the engine in i could not close the bonnet as the leads were to high.In the end i had to use coax wire to get the 90 deg bend from the dizzy. hope you dont mind the photo or the advice.
                          [ATTACH]81169[/ATTACH]
                          MMMM good point, in comparison with your pic mine now looks to me more like a spider
                          Can you give me more details on exactly how you achieved that great look with the coax please?
                            Hi Rob, i used the inner cable from an old tv lead i had laying around, ( there is more than one size, sky cable is thinner) i drilled a hole in the block where the sparkplugs should be this gives a good glueing point for the HT leads, offer up each lead & bend to shape before glueing into place.
                            Dont paint the leads befor gluing as this will give a stronger hold.
                            The thing i hate about a high dizzy's is that the leads to it have a 90 Degree connection to them.
                            Hope this helps & you are not affended by my comment.
                            [ATTACH]81212.IPB[/ATTACH]
                            I hope you dont think im showing off with my pic's but i to had the same problums you have but with a little out of the box thinking & help from othere's on this site a good finnish can be achived.
                              Hi Rob, i used the inner cable from an old tv lead i had laying around, ( there is more than one size, sky cable is thinner) i drilled a hole in the block where the sparkplugs should be this gives a good glueing point for the HT leads, offer up each lead & bend to shape before glueing into place.Dont paint the leads befor gluing as this will give a stronger hold.
                              [ATTACH]81205[/ATTACH]
                              Thanks for the advice John I will definitely give it a go now, or next time get a diesel
                              Cheers Rob.
