paint smug how do I get rid off
  • james pithouse
    • Dec 2014
    • 1295
    hi guy I have sprayed the fairings the metallic red ts-18 and like an idiot I am i put my finger on it and smuged it as i was putting it on the work top after i have sprayed it out side. So how do I get rid off it [ATTACH]273086[/ATTACH] [ATTACH]273087[/ATTACH]
  • colin m
    • 8755
    • Colin
    • Stafford, UK
    Being such an obvious part, I think I would let it harden and then sand to remove the blemish and re-spray.
    • PaulTRose
      • Jun 2013
      • 6468
      • Tattooine
      or strip and start again
      Per Ardua
        Thats just what I do in that siuation too.
        • stona
          • Jul 2008
          • 9889
          Take Colin's (colin m) advice and if for any reason that doesn't solve the problem, then plan B would be to take Paul's (beowulf) advice.
          Most important is to let the paint dry and cure before attempting to sort it out, otherwise you will definitely be starting again.
          • james pithouse
            • Dec 2014
            • 1295
            ok guys thanks I'll sand and get rid of blemish
            • james pithouse
              • Dec 2014
              • 1295
              just wondering if I sanded completely back all the parts will car metallic paint work or would it have to be model paint
                Jim get a can of mr muscle oven cleaner and put the parts in a plastic bag spray parts with the oven cleaner tie up and leave overnight, rinse in clean water and you will find you are back to the original plastic. Halfords do car paint for plastic in cans make sure you get the stuff for plastic, comes in loads of metalic colours.
                • james pithouse
                  • Dec 2014
                  • 1295
                  thanks ken will do . Did you want any hing form London like model wise or any bits for models as I will ask cousin ken when I go up there this month on 27th for a few days
                    No thanks jim
                      • 18271
                      Let it harden, flatten it with fine wet and dry and feather it in. Once dry and hardened it should not show after a careful polish.
                      • james pithouse
                        • Dec 2014
                        • 1295
                        taken back to basic still got bit of acrylic on. They do spray in enamel but not plastic paint will that be ok for plastic
                          Halfords do do paint for the plastic parts of cars but failing that house of colours do cans of spray for plastic but i think you would have to order it off the internet also the pound shop does some which i used (check out the lotus done in that paint, it does take a while to harden though and they only do gold and silver in metalic and not many other colours , it does have a super glossy finish though. I used it on the 1/16 vw karman also.
                          Cant really go wrong for a quid though.
                          • james pithouse
                            • Dec 2014
                            • 1295
                            ok thanks now go back to work ken lazy git
