Pocher 1/4 ducati panigale s
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    #76
    That is really starting to look pretty awesome Ken.
    Si vis pacem, para bellum.
      Thanks mate
        Hi all these are the screws that come with the kit.
        At a huge cost of 3.49 for 20 including postage I think these look better
        (Ron aka silver911 told me where to get them
          Thanks guys.
          Hi all here is the next update pocher would have you attach the rear sprocket like this
          Thing is the rear sprocket is attached via nuts screwed onto studs so grubs screws were used to fix it.
          Then a try of all we have so far.
            If you compare...the Titanic looks like a small boat....lol
            Looking amazing
              • 22770
              #81
              Just caught up Ken and some great work, I really like the air filter you've made.
                Hi all well flitting about decided to start on the front fairing it may not look it but it's a fairly complex bit
                  Moving along now, still a long way to go though, but at least it's looking like a bike now.
                  Not happy with the oxygen sensor wires I think they're too thick, they're networking wires I don't have anything thinner, any suggestions.
                    I always have a stock of lead wire in many thicknesses to cover things like this. I used .5mm for the ignition wires on the tractor build. This is an amazing kit.
                      Hi all well I've got to say I'm very disappointed with the hardware upgrade kit. I'm not an engineer and I don't have a box of assorted small diameter bolt hexnuts or assorted rods but Paul seems to think anyone buying his kit has them I now have to try and find some threaded rod for the foot pegs, anyway whingeing aside the heal guard is missing the attachment hardware Paul suggests to make sure you can get the centred you cut the heads off the bolts and glue them in place allowing you a chance to centre them
                      On closer inspection looking at the rear of the part there are two lugs where the bolts go through on the real thing which if drilled from the rear gives you the ability to centre them also giving you the realism of having the bolts sticking out the back once added
                      The top bolt on this bracket as supplied is a Philips screw.
                      Paul's solution is to cut the head off a socket screw and glue it over the screw
                        • 22770
                        #86
                        Wow she's looking great already Ken, even though your only half way through.
                          Hi all finished the rear suspension and made the rear stand as this thing is getting heavy and is not very stable standing on only it's rear wheel and the exhaust
                            • 22770
                            #88
                            That is coming along very nicely Ken.
                              I really love this kit. I'm working on the handle bars, there are more parts in just these bits than in some 1/24 car kits I've built (I'm not looking forward to the tiny decals)(They supply all the decals there are on the real bike) it has working break and clutch levers and a working throttle.
                              • flyjoe180
                                • Jan 2012
                                • 12390
                                • Joe
                                • Earth
                                #90
                                Fabulous work so far Ken, looks really good
