Starting My Yamaha XV1600 RoadStar
    Can't you fix it by drilling inserting a pin then joining the bits together with superglue
    • Snowman
      • Oct 2014
      • 2098
      #17
      As Ken says, this is an easy fix! Don't throw in the towel.
      • james pithouse
        • Dec 2014
        • 1295
        #18
        I'll try and repair it but don't hold your breath on holding in place. I wish they put the, suspension together for you, that easy it saves time and do not break as the spring is quit stiff and hard to hold up with one hand whilst trying, to put the clip in place to hold, the spring in place.
        • james pithouse
          • Dec 2014
          • 1295
          #19
          hi guy's got to order new kit for the part now completely snapped in 3 places
          [ATTACH]291079[/ATTACH]
            I can only see two bits there Jim, you need to be gentle with your models Jim, you caress the parts gently, lovingly coaxing them into place with gentle stroking. You don't just ram em together, show your models some love Jim
            • james pithouse
              • Dec 2014
              • 1295
              #21
              I did ken but it still broke lost third part now found it
              [ATTACH]291080[/ATTACH]
              • james pithouse
                • Dec 2014
                • 1295
                #22
                Order new kit for just the suspension part on 15/12/17 arrived today but, delivered to same number but it was wrong place to be delivered to, now got it i can finish it at last [ATTACH]292028[/ATTACH]
                • james pithouse
                  • Dec 2014
                  • 1295
                  #23
                  crap bike to build DO NOT BUY THIS BIKE SUSPENSION SNAPPED AGAIN SPRING TO TIGHT NEED THICKER SUSPENSION TRYIED ON OLD SUSPENSION AT DRILLING GENTLY DOES NOT WORK
                  • james pithouse
                    • Dec 2014
                    • 1295
                    #24
                    brand new suspension for the new kit trying to put spring on this is what happens
                    [ATTACH]292030[/ATTACH]
                    • james pithouse
                      • Dec 2014
                      • 1295
                      #25
                      NOW WHOLE NEW KIT AND THE ORGINAL KIT BIKE I STARTED IN BIN WHERE THEY BELONG GOOD RIdENS TO THEM
                      [ATTACH]292031[/ATTACH]
                      • james pithouse
                        • Dec 2014
                        • 1295
                        #26
                        emailed tamiya about this problem waiting reply
                          Could you perhaps make a resin cast of the suspension and thus have a harder more durable part? I'm just trying to think of things to salvage the situation...
                          I do know the frustration because I felt the same earlier with my Haunebu II from Squadron, which they refused to sort out. Tamiya is a different story and all I've heard is that they're very helpful!
                          I hope you pull the boxes out of the bin and give it a think instead of giving up. There must be some way to fix the dodgy part?!
                          • james pithouse
                            • Dec 2014
                            • 1295
                            #28
                            I have never tried resin as have never made a mold before. Jens that's why I emailed tamiya to build it for me and send it for free I hope
                            thanks for the idea
                              Jim GET THEM OUT THE BIN if all else fails make them hard tails (no suspension on the rear) you're giving up to quick there must be a way, look for other build logs of this kit. It's a tamiya so there won't be a problem with the kit. Maybe it's the instructions which are not clear and you are trying to attach bits wrong , as I said if all else fails hard tail them.
                                Jim I just downloaded the instructions and it seems fairly clear to me how it should fit together it also looks as though it would be simple enough to convert it to hard tail
