hi everyone, will have to start tis soon had it since the early 80s time it was done, seems as though all the parts are there, over 400 all together will probably start it in the next few weeks !
1/6 scale police Harley davidson
Tags: None
loads of bits ,some metal, some rubber but mostly plastic . here's just a few !Attached Files- tamiya harley ,,,metal parts.jpg (3.1 KB, 3 views)
- tamiya harley davidson police bike ... frame and various fittings (1).jpg (2.6 KB, 3 views)
- tamiya harley davidson police bike ... frame and various fittings (2).jpg (3.0 KB, 2 views)
- tamiya harley davidson police bike ... frame and various fittings (3).jpg (3.0 KB, 3 views)
- tamiya harley davidson police bike ... frame and various fittings (4).jpg (3.0 KB, 5 views)
- tamiya harley davidson police bike ... frame and various fittings (5).jpg (3.2 KB, 3 views)
- tamiya harley davison police bike (9) various chrome bits.jpg (3.7 KB, 5 views)
- tamiya harley davison police bike (10) alloy coloured parts, headlight shroud etc.jpg (3.9 KB, 4 views)
- tamiya harley davison police bike (10) various chrome bits.jpg (3.7 KB, 3 views)
- tamiya harley davison police bike (11) various chrome bits.jpg (4.0 KB, 3 views)
- tamiya harley davison police bike (12) alloy coloured parts primary cover sprockets etc.jpg (3.8 KB, 3 views)
- tamiya harley davison police bike (18) red and clear bits.jpg (2.0 KB, 3 views)
just to say that all the black and white parts will be painted and lacquered to get rid of the plastic look !Comment
heres a few parts ready for tidying up and painting, frame and most of the fittings various other bits to be fitted later on, seat post which is actually sprung ! and swinging arm which will pivot on the frame when fitted !Comment
some more parts, fit is very good just a bit of tidying up . detail is excellent as you can see on the oil pump and rocker box, 4 small chrome cylinder base nuts and 5 cylinder head bolt heads to be fitted as wellComment
a few more parts to get ready, battery top and front are black but I shone a light on them to show the detail, oil tank is also black there's even two seperate little connecters for the oil lines to fit to which I forgot to include in the photo ! primary inner housing and cover , starter solenoid and linkage and pedal for the siren all to be tidied up and necessary parts primed and painted !Comment
radio parts and starter motorAttached FilesComment
hello everyone ,due to not feeling to well I've not been on here much, but i'm back now ! not much done on the Harley but here's the latest work done cylinders and gearbox completed and ready to fit to crankcase ! cylinder base and head nuts were all separate as were the red rocker shaft nuts, had to paint the red bit on as well !Comment
oil tank and battery tray, coil and ht leads complete..... chrome filler caps , and top and bottom oil line connectors on oil tank were all separate pieces,as were the coil ht leads and spark plug caps !Comment
