Rotten Box - Rotten Kit ! Matchbox 1/12th Suzuki RG500
  • tigersteve
    • Jan 2018
    • 678
    #16
    Originally posted by simontie
    do you still have the old decals? I would be tempted to cut them out soak them and see if they will separate?
    also look up “MICRO-SOL” decal softener not sure if i can add a link to the destruction pages but goggle it worth a read and might assis you in using the originals or in fitting the new studio27 ones or even a combination of both!!!
    your body work looks ok seepage is always an issue its a learning curve to make sure you get good adhesion on the tape i always try to remove it very soon after so i can wash any issues away most can be masked by the decals also if you feel brave gently rub it all down with 1500/2000 grit all in the same direction then add a clear coat you will love the finish apply your decals and recoat clear again.
    Hope this helps
    Thanks for the advise , will try the Micro-Sol , the biggest task will be the front number background , the one I have is too small and the original Sheene kit dosen't come with that in yellow so it will have to be more trial and error I guess !
      • 18959
      Would somet like this help?
      Prevents old decals from cracking, seals inkjet printed decals, strengthens very thin decal film. If you use decals you need a bottle
      John may well stock it.
      • tigersteve
        • Jan 2018
        • 678
        #18
        https:tongue-out3:/www.emodels.co.uk...iABEgJfxPD_BwE
        Thanks for your interest ! - is that different to Micro-sol ?
        I have ordered some of that and will try it ...
          • 15821
          Hi Steve
          It is looking rather good. You have certainly persevered to get to this stage. I'm sure you'll sort the decal issue.
          • colin m
            • 8806
            • Colin
            • Stafford, UK
            #20
            I have a bit of a thing for old Matchbox kits. Whilst I'm not a bike person, I'm looking forward to this build.
            • simontie
              • Jan 2010
              • 1506
              #21
              Challenges,,, use the micro sol and best fit the studio ones, or cut a circle in the some 2” masking tape (50mm forgot your in france lol) and spray it yellow..
              Why is common sense not so common?
              • tigersteve
                • Jan 2018
                • 678
                #22
                Nearing completion !
                Some touching up and the fairing to fit still .......
                Good thing Barry is still smiling !!Click image for larger version
ID:	1115215Click image for larger version
ID:	1115216Click image for larger version
ID:	1115217Click image for larger version
ID:	1115218Click image for larger version
                • tigersteve
                  • Jan 2018
                  • 678
                  #23
                  Just about done - not too bad , still needs a bit of work ......
ID:	1116368Click image for larger version
                    Looks great to me.
                    • Steven000
                      • Aug 2018
                      • 2830
                      • Steven
                      • Belgium
                      #25
                      Turned out very nice Steve :thumb2:
