Homemade Honda Cub C70 1/35th scale
  • rtfoe
    • 9084
    Hi, anyone wanting to scratchbuild Honda Cub C70 can do it as it is possible or get the Dio-Park kit now available.
    In 2007 I wanted a local universal motorbike that is instantly recognize in an Asian environment set in the 70's. There were none in the market at the time except for out of scale toy metal ones. So I set about collecting research and photos of the real bike and started with a scaled picture profile of one.
    Then I set about creating the skeleton framework and scrounged the right diameter wheels from an Italeri Harley Davidson...surprised it had almost the same diameter rim but I had to trim down the tyres of its thickness. If I had more patience and skill I would have thinned it further to scale and because of that the bike was scaled around 1/32. The figure came in handy to make sure I kept the scale between 1/35 and 32.
    I made sub-assemblies of the parts that would be added to the frame just like parts from a sprue. Most of it were from plastic strip and rod carved and sanded to shape. I shaved off certain parts from the Harley that looked similar to parts on the Honda. The mudguards were two pieces of thin card sandwiching a thicker one bent around the tyre and sanded down. Putty was added where ever contours needed building up. I didn't bother with working parts and just glued where ever it needed connecting
    The next image shows the state of art my camera was at the time...no macro. Anyway it's the shock absorbers and foot rest made from different sized rods and laminated with Tamiya tape. Honestly even with my optivisor on they looked just like this. :smiling6:
    The next hardest process was the splash guard. To get the curve and slope, cuts were made at stress points and then a layer was laminated on the outer side. The little aperture for the choke and petrol mix levers was pre-drilled before attaching the splash guard. Bits of plastic simulated the levers and pipes.
    At this point I was regretting not sanding the tyres thinner...I still pressed on. More to come later.
    • 18903
    Great bit of scratch building. I saw one of these (actually a C90) in restored condition a few months ago. First one I’d seen in years.
    • rtfoe
      • 9084
      Thanks Tim, not many on the road now, being overtaken by later models but occasionally there are some ridden by our local bread man or roti man.
      Would like to do one of these some day...wonder how to wrap the goodies in simulated cellophane wraps.
      You still see these bikes in Bangkok and Ho Chi Min city or beach resorts in SEA for hire.
        • 15693
        Hi Richard
        Amazing scratch building. I wouldn't know where to start. The sort of thing our Simon T would have tackled.
        • rtfoe
          • 9084
          Thanks Jim, here's more of it...
          After laminating the splash guards and sanding into shape I sprayed black primer to check on anything not right and corrected the shape of the petrol tank which sits under the seat. Then proceeded to detail the exhaust with thin welded lips from styrene strip. I bent a thick wire for the connecting pipe.
          I mixed some putty and kneaded to shape the seat and added the belt from flattened putty. On the real bike there is a gap underneath the seat between the petrol tank and rear mud guard.
          Detail on the front fork and mud guard. Little bits of rod and styrene strips were used bolts and hub assembly.
          The handle bars were thick wire bent at an angle, attached to two styrene tubes that were glued at right angles and coated with putty. A disc for a lamp was attached to one end of the tube and the other had a rod inserted to go through another tube attached to the frame and attached to the fork. This allowed for directing the front wheel.
          More later.
          • rtfoe
            • 9084
            Hi, the bike didn't come with a basket when it was imported. The basket was installed locally. I made it from brass wire mesh following plans I drew up.
            The cut shape was folded and secured with CA and anchored further with more CA. I painted parts of the spoke, engine and absorber in chrome silver. Just lying in the foreground is a wire bent to make the kick starter.
            I flattened the top of the center of the handle bar for the speedometer and added two signal lights on either side of the main lamp.
            At this stage it started to look like the Honda.
            • adt70hk
              • Sep 2019
              • 10409
              Wow!
                • 15693
                Hi Richard
                Excellent work. Certainly impressive to build a small bike at 1/35 scale.
                • JR
                  • May 2015
                  • 18273
                  Another deserving appearance of the Race Towers .
                  • Mini Me
                    • Jun 2018
                    • 10711
                    Excellent "Scratchduggery" Richard and that is a "cute" little model..........The Museum I frequent has a few of these in unrestored condition....seeing this just takes me back to my youth. First bike I ever rode.....then later on an S90..........thought I could fly.
                    • rtfoe
                      • 9084
                      Thank you gentlemen...Andrew, Jim, John and Rick. :smiling2:
                      Surprised that there were Cubs in the US as I haven't seen any pictures of them. I've seen Vespa's though. I bet a convertible must have been more popular.
                      There are a few things added here like the piping for the seat made from fuse wire. and the kick starter and foot break lever.
                      More detail on the handle bar with box switches and throttle guard with the hand break lever. Also added were reveres mirrors on fuse wire and the speedometer edge with fuse wire too. On the side is a flip flop I scratched.
                      Shaped some plastic rods for rear indicator lights and the break light cut from a single piece of thick plastic block.
                      On the left side I fitted the foot gear levers from copper wire and a piece of plastic strip. The footrest was carved from thick plastic rod.
                      • Mini Me
                        • Jun 2018
                        • 10711
                        NICE!! :thumb2:
                        • rtfoe
                          • 9084
                          Thanks Rick...I managed to find a riding figure that fitted the little Honda, he's a Waffen SS rider from Tamiya I think.
                          I removed the basket for ease of painting the body in the familiar grey, one of many colors that it came in. You will notice a strip of plastic just under the seat for the Honda winged emblem.
ID:	1139940Click image for larger version
                          At this point the indicator lights haven't been painted but the chrome parts picked out.
                            • 18903
                            That’s looking great. lovely job on the body and seat. The leg guards are super as well.
                            The figure looks like a re-enacter going to a gig in full kit LOL....
                            • rtfoe
                              • 9084
                              Thanks Tim, ya he does look like a re-enactor riding the bike to a show.:smiling2:
