Tamiya Repsol Honda RC213V
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4592
    • Bob
    • London
    Morning all. :smiling3:
    I decided it was time to try my hand at a motorcycle, never built one before so why not jump in at the deep end with this.
    It's a very nicely detailed kit and typical Tamiya quality. I spent much of the Easter weekend turning this
    Into this
ID:	1148075Click image for larger version
ID:	1148076Click image for larger version
ID:	1148077Click image for larger version
ID:	1148078Click image for larger version
ID:	1148079Click image for larger version
    So far so good, although the masking of the body panels looks like it will be fun. :smiling3:
    Si vis pacem, para bellum.
  • adt70hk
    • Sep 2019
    • 10395
    Not a bike man myself but nicely done so far.
    ATB.
      • 15607
      Hi Bob
      I have only ever built a little 1/35 motorbike but never something like this.
      All I can say to your progress so far is WOW! - that looks great.
      It's gonna be a striking model with all those decals.
      jim
      • Peej
        • Aug 2014
        • 919
        Done a couple of bikes myself, both tamiya. You've done a cracking job of that engine. Good luck with the rest of the build.
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4592
          • Bob
          • London
          Cheers gents.
            • 18871
            That looks great Bob. I think you could start it if you added petrol They are very nice kits actually. Building one feels just like building a real bike.
            • Mr Bowcat
              SMF OG
              • Dec 2016
              • 4592
              • Bob
              • London
              Cheers Tim.
              It certainly makes a change from building cars & AFV'st as there is actually something under the hood.
              • PaulTRose
                • Jun 2013
                • 6427
                • Tattooine
                not only have you jumped in the deep end, you done it off the 10m diving board!!
                have fun, you will find it a refreshing change
                Per Ardua
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4592
                  • Bob
                  • London
                  Cheers Paul.
                  In for a penny, and all that.
                  • tigersteve
                    • Jan 2018
                    • 678
                    Nice start ! Those Tamiya motorcycles always fit together well and look great - I'll be tuning in for the build !
                    • Mr Bowcat
                      SMF OG
                      • Dec 2016
                      • 4592
                      • Bob
                      • London
                      Cheers Steve.
                      Thanks to whichever mod moved this to the correct section.
                      I've been working on getting the back end completed. First step was the pit stand and swing arm.
                      Then it was on to the brakes (also got the front disks done at this point), chain, suspension and radiator.
                      And while I was at it I got some of the body parts glued together, sanded, filled, sanded again and primed. I also got the first colour down on the wheels, these are due to be gloss coated today so I can install the back end to the frame.
                      • Mr Bowcat
                        SMF OG
                        • Dec 2016
                        • 4592
                        • Bob
                        • London
                        Morning all.
                        Not much modelling done this weekend, the ranges have finally re-opened so I was out punching holes in paper most of yesterday.
                        I did get the swing arm together and fitted to the frame.
ID:	1148542Click image for larger version
ID:	1148543Click image for larger version
                          • 18871
                          Looking fine Bob. It really does look like an actual bike build shot rather than a model.
                          • Mr Bowcat
                            SMF OG
                            • Dec 2016
                            • 4592
                            • Bob
                            • London
                            Cheers Tim.
                            • Mr Bowcat
                              SMF OG
                              • Dec 2016
                              • 4592
                              • Bob
                              • London
                              Morning gents.
                              Small update on this one, I've been working on getting the remaining parts cleaned up and painted.
                              I'm using Gravity paints for the panels, first time I've used these and it mostly went OK. I had some paint build up at the masking demarcations, but this seemed to be easily removed with some micromesh sanding. It's most likely something I did, there's always a learning curve with new paints.
                              I'm currently debating whether to clear coat the panels before applying decals. I'm thinking its probably going to be easier to apply decals with the panels fitted to the frame and a clear should help protect the paint from damage when removing later for a final clear.
ID:	1149018Click image for larger version
