1/9 Protar Ducati 916 racing.
  • GerryW
    • Feb 2021
    • 1757
    #31
    Coming along nicely, pity that they didn't put in a spring link in the chain, then it'd be a lot simpler in a way! :thumb2:
      • 18931
      Build it like a real one Andy
      • outrunner
        • Apr 2019
        • 2420
        #33
        Yes, having restored one or two bikes in the past I am looking for the easy way to do it, unfortunately kit makers do not think the same as bike manufacturers when it comes to building them from a pile of bits.
        Andy.
        • Mark1
          • Apr 2021
          • 4156
          #34
          Looking good though :thumb2:
          • outrunner
            • Apr 2019
            • 2420
            #35
            The pile of bits is getting bigger, one of these days it may come together.
            Wheels done, not looking forward to fitting the decals to the tyres.
            [ATTACH]422262[/ATTACH]
            Front forks and top yoke/handlebars.
            [ATTACH]422263[/ATTACH]
            [ATTACH]422264[/ATTACH]
            I see in the photo a seam line on the fork leg but it will never be seen under the fairing, I hope.
            Frame halves painted up and exhaust done, bit of a fiddle with non-stick decals but managed with thinned PVA.
            [ATTACH]422265[/ATTACH]
            [ATTACH]422266[/ATTACH]
            Andy.
            • Mark1
              • Apr 2021
              • 4156
              #36
              Looking good,what with broken bolts and chains you must be past the worst now.
              • GerryW
                • Feb 2021
                • 1757
                #37
                Looks like you're on the home straight now :thumb2:
                  • 18931
                  The pile of bits gets bigger....and better....
                  Dont envy you those decals on tyres either. I think I’d be tempted to try and paint them on.....
                  • john i am
                    • Apr 2012
                    • 4019
                    #39
                    You deserve a medal for you patience with that chain.Builds looking good and that paddock stand you scratched is really good. I love motorbikes I should build one someday. Here's mine 1:1 scale.
                    Cheers John.
                    • outrunner
                      • Apr 2019
                      • 2420
                      #40
                      I have done a bit of a test fit, luckily no glue used as another couple of problems have arisen one of which can be easily overcome.
                      [ATTACH]422350[/ATTACH]
                      With the frame together the airbox will not fit so I will have to unscrew the front frame fixing and spread the frame to get the airbox in. Something else that looks wrong is the chain. I tested the length before and it was too tight to fit so I fitted another link and now it seems to be too long, not an easy fix.
                      Andy.
                      • outrunner
                        • Apr 2019
                        • 2420
                        #41
                        [ATTACH=CONFIG]n1150457[/ATTACH]
                        Cheers John.
                        The paddock stand is part of the kit John and as for 1:1 scale here is mine.
                        [ATTACH]422351[/ATTACH]
                        Andy.
                        • GerryW
                          • Feb 2021
                          • 1757
                          #42
                          Sounds like you need a half link - yeah, right! :smiling5:
                          No adjustment on the rear wheel?
                          • outrunner
                            • Apr 2019
                            • 2420
                            #43
                            I am afraid not, the real Ducatis have an eccentric adjuster on the single sided swingarm models but no such luxury here.
                            Andy.
                            • Mr Bowcat
                              SMF OG
                              • Dec 2016
                              • 4608
                              • Bob
                              • London
                              #44
                              Just caught up with the build Andy, all looking very nice so far.
                              Si vis pacem, para bellum.
                              • GerryW
                                • Feb 2021
                                • 1757
                                #45
                                Andy.
                                Out comes the file and stretch the hole by half a mil, though that could be another kettle of fish! :upside:
                                Take it that it's a 'concentric' swingarm, where chain tension is the same all the way through the travel.
