Tamiya Yamaha YZF-R1
Cheers Steve.
I've been working on the paintwork for the last few days. First up was the body panels, painted, glossed, decalled and glossed again. The kit comes with a decal for the red accent on the front fairing, but I decided to mask and paint it instead.
Then I cleaned up all the remaining parts and got them painted.
So with everything now painted it's just a case of getting it all put together.Si vis pacem, para bellum.Comment
Cheers guys.
Started putting it together yesterday.
Front end.
Seat and fuel tank.
Then the problems started when I tried to fit the cowl.
I can only assume that the internal headlight piece that connects to the frame isn't correctly located within the cowl. There's nothing else for it, it's going to have to come apart. I've ordered some debonder from Amazon, not sure what effect this will have on the paint so might end up having to strip it all and start again.Si vis pacem, para bellum.Comment
That’s a real blow Bob. Sure you’ll sort it out though, because this is looking good enough to ride....Comment
