Aoshima 1/12 Kawasaki 750 RS
  • scottie3158
    • 14202
    • Holbeach
    #16
    I will say one thing for you mate, you certainly have a diverse collection I never know what's coming next. I will follow along.
    • adt70hk
      • Sep 2019
      • 10409
      #17
      Very true!
        I'd really get bored with doing one genre, so yes, I do jump around a lot! Although, I've only ever made one SF model ( and that was for a mates' kid ), and never any fantasy stuff. I've made one Toon ( not likely to make any more ) but I'll generally have a go at anything!
          Having problems with my OA. The next batch of plated bits have had their bath
          I couldn't assemble the front forks without the front mudguard - which are metallic red, so the first attempt at left-handed airbrushing...........................
          Doesn't look particularly metallic in the pictures, but it is! A couple of coats of gloss varnish & they'll be read for use.
          Assembly of the rear wheel & swing arm. Had to use flash, as it's getting dark earlier!
ID:	1163878Click image for larger version
          Depending on how my hand is - I'll either prime & basecoat the frame, or assemble the forks & wheel.
            • 18908
            Starting to come on Dave. Just like building a real oneโ€ฆ..
              Frame basecoated ( & tank dry fitted ). Engine assembled, just the leads/pipes to add before fitting into the frame
              Might be a bit of a juggle, getting all the bits to fit between the frame halves!
                Still having hand problems, but managed to fit the engine & assemble the forks
ID:	1164024Click image for larger version
                I used True Metal on the forks - it needs a bit more work to improve the finish...............
                  These will be last pictures posted in the 'under construction' section. Not a lot of parts to add, decals & detail painting & the last of the cables........................
                  Those oil pipe to the cooler are a real b****r to fit!
                  The tyre rubber is very soft & seems to scuff easily - I'll have to see if I can even the colour out somehow.
                    Finished
