HONDA RC166
  • simontie
    • Jan 2010
    • 1506
    #16
    Got to be the SR for me. I owned an SR 500 after I passed my test…..
    I had the xt500, wish i still did not sure i could kick it now but the resale value is of the planet
    Why is common sense not so common?
      • 18884
      I know I couldn’t kick one over now. Mine had a decompressor lever but I never worked out how to use it LOL. No internet in those days I just used to get it to TDC, the. Throw myself up and come down on it straight legged. Fired every time…..but you needed boots with a good heel.
      • minitnkr
        Charter Rabble member
        • 7510
        • Dayton, OH USA
        #18
        I remember seeing a kid launched over the bars kicking an old knucklehead hog that kicked back.
        • simontie
          • Jan 2010
          • 1506
          #19
          Thumbs and knees spring to mind numbed them a few times, always when you least expected it,
            • 18884
            A bad kick back only happened to me once. That was when I realised the value of boots with a good heel :anguished:. My foot slipped off as I was kicking it over. Never quite went over the bars, but it was close. My ankle was hit by the kick lever and was so bruised it looked like I was wearing a purple sock :anguished: . The kick start bump stop was fractured and blown straight through the engine casing. I could get a spare bump stop no problem, but the casing was another matter. I stripped it, cleaned and degreased it thoroughly, roughed up the edges of the hole with a coarse file to aid adhesion, and built up a repair patch out of 24 hour araldite over several days. Last job was reinforcing the outside with a square of aluminium sheet. It was a right bodge job, but I was an impoverished 19 year old and it stayed oil tight for the couple of years I owned the bike.
            • simontie
              • Jan 2010
              • 1506
              #21
              I had a sump like that after a run through the woods with no belly pan a tree stump split the alloy sump and like you, araldite to the rescue....on the 500 it was a bolt on affair and like unicorn snot to find at an affordable price no eBay back then!!
              • simontie
                • Jan 2010
                • 1506
                #22
                Ok well i would say full steam a head but after a full night …
                i have stripped the chrome soaked it this morning, then trimmed & assembled 1 wheel and now its clamped till tomorrow morning this is not for the faint hearted 1 wheel to go…
ID:	1182073Click image for larger version
ID:	1182074Click image for larger version
                  • 18884
                  Looking great Simon. Very fiddly I should think.
                  • simontie
                    • Jan 2010
                    • 1506
                    #24
                    Ta da 8 parts in this 1 wheel 9 if you include the valve (not fitted yet)
                    simon Click image for larger version
ID:	1182121Click image for larger version
                      • 18884
                      Looks very good Simon.
                      • tigersteve
                        • Jan 2018
                        • 678
                        #26
                        Nice job !
                        • simontie
                          • Jan 2010
                          • 1506
                          #27
                          Ok both wheels done second was easier not much!! ok any advice on best chrome? Was going to go with alclad107 on a base of 305 black any offers?
                          also started the engine will post once i get it together
                          simon
                          • simontie
                            • Jan 2010
                            • 1506
                            #28
                            hi all frame & wheels engine started but need to. Pick up some paint for a couple of bit so its on hold for now, wheels are on hold now till I get the alclad, so just sticking bits I can together in preparation, fairing carrier on the frame is a bit flimsy no way that will survive the build!!
ID:	1182196Click image for larger version
                            • simontie
                              • Jan 2010
                              • 1506
                              #29
                              Ok SR it is, wire arrived today have to say 0.3mm isn't as big as i thought :flushed:, but were on ill open another tread for the build
                              simon
                              • simontie
                                • Jan 2010
                                • 1506
                                #30
                                Ok managed a bit of the RC this evening, cylinder’s assembled tricky but a really nice piece, carbs including the DP bell mouth intakes, bottom of cylinder crankcase and even managed to paint the sump and rocker covers busy night
ID:	1182749Click image for larger version
ID:	1182750Click image for larger version
ID:	1182751Click image for larger version
ID:	1182752Click image for larger version
ID:	1182753Click image for larger version
