Aoshima Yamaha SR400
  • simontie
    • Jan 2010
    • 1506
    Ok as promised, heres the kit all i have done so far is cut out thechrome wheel parts and stripped them down.
    also i made this jig 2 round 6mm hardboard circles (just easier to cut) now i plan to bond one on to the other and this should hold the wheel parts in place while i re spoke them thats the plan anyway idea is it will keep it square while the glue sets
ID:	1182640Click image for larger version
ID:	1182642Click image for larger version
ID:	1182643Click image for larger version
    simon
    Why is common sense not so common?
  • simontie
    • Jan 2010
    • 1506
    Part one no shaky hands here!! ok so first off i marked the valve position on the hub & the rim although im not cutting it out, then i scribed the direction of each spoke inner and outer L&R both sides that was fun next up i drilled a .8mm hole in the centre rim by squaring across the diagonal line from the spoke, starting the hole and stopping just after to turn the wheel slightly so i could follow the correct angle or as near as dam it, once drilled i cut away the remainder of the spoke and tested with the nipple tube testing all holes as iwent that they were clean and true (ish)
ID:	1182659Click image for larger version
ID:	1182660Click image for larger version
ID:	1182661Click image for larger version
    i should say I’v never done this before so its a learning curve for me, but no disasters yet anyway
    simon
    • serendpt
      • Aug 2022
      • 9
      Hi Simon,
      How do you find the quality of the Aoshima kit? I'm looking to get some in the near future as their prices locally are quite attractive.
      Also, why and how did you strip the wheels down?
      Khairul
      • simontie
        • Jan 2010
        • 1506
        Originally posted by serendpt
        Hi Simon,
        Khairul
        Quality is quite good even though this is an old kit, stripping it down to remove the chrome plating (soaking it in bleach 50/50 mix works fine) it looks better repainted and adhesion is better when glued, stripping the wheel down was a challange to see how its done but also i believe the result will be more realistic.
        simon
          • 18264
          Off to a good start Simon.
          I edited your post so the photos are Full Image and not thumbnails.
          • simontie
            • Jan 2010
            • 1506
            Thank you :thumb2:
            • simontie
              • Jan 2010
              • 1506
              Ok well apart from some dodgy drilling rim is now free of the hub and primed, will top coat silver.
              hub to cut out and drill remove the moulded spokes and clean up
              i put a centre pin in the jig to line up the hub and rim but i made a small mistake by not measuring the dish of the wheel but i think (correct me if I'm wrong) if i split the difference width wise of the hub and pack up off the centre pin this should give me a reasonably accurate dish?
              simon
ID:	1182844Click image for larger version
ID:	1182845Click image for larger version
                • 18264
                Th dish on the wheel being equal depends on a couple of things. Type of brake. Drum or disc. also rear wheel shaft of sprocket the one side and disc the other or drum.
                So if you have a rear wheel with chain drive the dish will compensate for the sprocket if there is a disc brake the other side that will even it out a bit. same with the front wheel depending if a drum; even dish. Single disc; shallower on the disc side. Two discs; even but shallow.
                I did suggest the easy way was to take a few spokes at a time, then you have the pitch, the dish and the lacing to follow as you go. A bif of a faff stopping and starting all the time but hey, that's what we do all the time. Glue a bit, wait, paint a bit wait, glue a bit more, paint a bit more.
                • simontie
                  • Jan 2010
                  • 1506
                  I did say it was a learning curve, & i wanted to paint the hub x11 by air brush without the nipples in place looking at the origional pictures i have its quite evempnly balanced and i think i can true it up once its together, it's a bit more of a challenge but I’ll see how it progress thanks
                  simon
                  • outrunner
                    • Apr 2019
                    • 2420
                    Having rebuilt a few full size motorcycle spoked wheels the trick is to measure the dish/offset before you start taking it apart. Of course, if you get it wrong it is just a bit time consuming to get it sorted, not so with a plastic model wheel but I should think you will be OK.
                    Andy.
                    • simontie
                      • Jan 2010
                      • 1506
                      Ok well i have the nipples in place and 1 spoke sitting in place not glued as i have more work to do to the nipples but heres where i am Click image for larger version
ID:	1183228Click image for larger version
                      • simontie
                        • Jan 2010
                        • 1506
                        A little bit fiddly but looks ok for a first attempt still need to finish of and clean up but much better than the chrome plastic. Im sure the next one will be better Click image for larger version
ID:	1183337Click image for larger version
ID:	1183338Click image for larger version
ID:	1183339Click image for larger version
ID:	1183340Click image for larger version
ID:	1183341Click image for larger version
ID:	1183342Click image for larger version
                        • JR
                          • May 2015
                          • 18273
                          That's some serious work there Simon, love the jig ,most impressive.
                          • simontie
                            • Jan 2010
                            • 1506
                            Thanks john it was hard on the eyes too, but once started it came together quite well hooking the inner spokes is the hard bit outer’s were less difficult as you can see the hole. (Just)
                              • 18884
                              Looks very fine to me. Well worth it.
