Aoshima Yamaha SR400
    • 18271
    Nice!
    It is both a mental and physical challenge.
    You nailed it!
    • The Smythe Meister
      • Jan 2019
      • 6248
      #17
      Wow!! Lovely stuff :smiling3:
      I'm considering respoking the wheels for my Italeri 1/9 Zundapp Combi, so your work here I am shamelessly going to copy!!
      That really does look most excellent,painstaking, but CERTAINLY worth it if you can get that kind of result :smiling3:
      Andy
      • simontie
        • Jan 2010
        • 1506
        #18
        Looks very fine to me. Well worth it.
        thank you there a few areas i need to work on but yes very happy with results
        Why is common sense not so common?
        • simontie
          • Jan 2010
          • 1506
          #19
          Originally posted by Ian M
          Nice!
          You nailed it!
          most definatly challanging simon
          • simontie
            • Jan 2010
            • 1506
            #20
            Andy
            your welcome, a few pictures are the key, for the pattern & once the first couple of inner ones are fixed its easy enough to follow but .3 wire in a .4 hole blind is fun while holding in place and appling super glue...
            i also found that using an off cut of the 0.3 and sliding this through the nipple hole helped guide the nipple in to place,
            i was planning on doing the back wheel slightly differantly, on the outter side of the rim where the tyre seats i was going to centre drill it out and push the tube through to the desired length and cutting it off once in position, i was left with a few ragged ends, very hard to clean up but will see how it works out
            simon
            • simontie
              • Jan 2010
              • 1506
              #21
              Ok engine is just about there top and bottom complete, but a fair bit of fettling to get it here will press on as per plans nothing painted and i must have a good 40% of it soaking in bleach a lot of plated parts that just look so ugly ….Click image for larger version
ID:	1183596Click image for larger version
                • 18271
                I found it easier to insert the spoke in through the hub first then out through the rim and give it a good drop of thick CA. Then trimmed them to length after.
                • simontie
                  • Jan 2010
                  • 1506
                  #23
                  I might try that on the rear wheel when i get to it thanks for the tip
                  simon
                    • 18908
                    Excellent progress Simon. The wheel has come out really well. Engine isn’t too shabby either :thumb2:
                    • simontie
                      • Jan 2010
                      • 1506
                      #25
                      Ok due to other issues not as far on as i hoped but chrome plate i dipped yesterday has gone parts look so much better now, see how i get on tomorrow Click image for larger version
                      • PaulinKendal
                        • Jul 2021
                        • 1608
                        • Kendal
                        #26
                        Those wheels are fabulous, Simon! Such a massive improvement over the stock ones - you nailed it!
                        • simontie
                          • Jan 2010
                          • 1506
                          #27
                          Well as mentioned in RC166 a busy week
                          engine carbs sorted, engine now in frame started rear wheel build, and did a spot of painting. Few other wee bits done but you can tell its not by Tamiya but should turn out ok more when i have them
                          simon Click image for larger version
ID:	1184272Click image for larger version
ID:	1184273Click image for larger version
ID:	1184274Click image for larger version
ID:	1184275Click image for larger version
                          • simontie
                            • Jan 2010
                            • 1506
                            #28
                            rear wheel done just need to clean up the hubs but looking ok for a first time second was a little easier Click image for larger version
ID:	1184316Click image for larger version
ID:	1184317Click image for larger version
ID:	1184318Click image for larger version
                              • 18908
                              Really nice work. Reminds me of my old SR……
                                • 18271
                                I considered a real one of these a few years ago as a project bike to make as a Cafe racer. I was amazed by the prices they went for.
                                All these bike builds of late I will have to try one (again) some time...
