A quartet of Ducati. Part 2: The 888
  • simontie
    • Jan 2010
    • 1506
    Box art and sprue parts, i have cut out the frame and a few other parts the chrome swinging arm is in 3 parts and i bonded these together to save stripping them as the finish was very nice and joints are hidden apart from that i haven't done much to it but had a look while the 900 was drying off
    simon Click image for larger version
ID:	1185979Click image for larger version
    Why is common sense not so common?
  • simontie
    • Jan 2010
    • 1506
    Hi All well i have the engine, frame and rear damper built up as far as i can go for now Click image for larger version
ID:	1186217Click image for larger version
ID:	1186218Click image for larger version
ID:	1186219painted the mud gaurds and stuck what i can together on the exhaust system stripped forks and painted the tubesClick image for larger version
ID:	1186220thats it for now .. off to Mallorca for a few days be back in a week or so i will check in most days, in between chasing a 5 year old around the beach and pool not sure this will be much of a break
    catch up soon …
    simon
    • simontie
      • Jan 2010
      • 1506
      Hi all, well made it back had a great time with the wee one never out of the pool or sea ready for a rest now ….
      ok up date on B2 i have finished the frame and bonded the pipes still a bit of work to do on them but here’s the latest hope to get the engine in later
ID:	1186734Click image for larger version
ID:	1186735Click image for larger version
ID:	1186736Click image for larger version
ID:	1186737Click image for larger version
      Simon
      • simontie
        • Jan 2010
        • 1506
        Weekend‘s work exhaust painted and fitted. Swinging arm and wheel assembled will try and get this mounted in the frame later looks like fun…
        building has been good only disappointment’s have been the decals for the exhaust unlike some carbon decals these have just not settled and really are spoiling the look of the system i will try some more micro sol and if they don’t settle i will have to pull them off most prominent on the larger section of the can both sides but same on the smaller sections its also a worry for the main decals fingers crossed these will be ok.
        not much more to do apart from the tank, fairing & bars, forks are done just not pictured sorry.Click image for larger version
ID:	1186953Click image for larger version
ID:	1186954Click image for larger version
ID:	1186955Click image for larger version
ID:	1186956Click image for larger version
        • simontie
          • Jan 2010
          • 1506
          hi thursday up date heading in the right direction front end is on rear end is on, fairing primed white then yellow, i think all the other bits are ready to go just need to touch up in a couple of places and new exhaust decals have arrived need to strip the old ones in place:rolling:ANY tricks for removing the old ones?:thinking:
ID:	1187185Click image for larger version
ID:	1187186Click image for larger version
ID:	1187187Click image for larger version
ID:	1187188Click image for larger version
ID:	1187189Click image for larger version
          • Mr Bowcat
            SMF OG
            • Dec 2016
            • 4600
            • Bob
            • London
            Looking good Simon, sorry to hear of your decal woes. :sad:
            In terms of decal removal, the only time I had to do it I just kept applying decal solution (keeping it soaked) and rubbed at it with a cotton bud. Eventually is dissolved enough and became a goopy mass that I was able to remove. MicroSet actually says "decal remover" on the bottle.
            For stubborn decals, have you tried the Ultimate Modelling Products decal solutions? They do a normal, strong and extra strong. The strong is about the same as MicroSet, but the extra strong is very good at thick decals (but may melt thin decals). Also, have you tried applying hot air to stubborn decals, I find this helps enormously. I have one of THESE which works well.
            Si vis pacem, para bellum.
            • simontie
              • Jan 2010
              • 1506
              I will give the microsol a blast not looking forward to the goo. I soaked them in warm water but and once i applied them to the can the long sides just cracked and split old kit i have had it a while. Will keep any eye open for the softeners the heat gun great looking tool its in the basket thanks Bob
              simon
              • simontie
                • Jan 2010
                • 1506
                Evening not quite how i thought i would be spending mine but stripping is working well slow but just about there, on the plus side yellow primer really did bring out the red.(thanks Tim M)
ID:	1187234Click image for larger version
ID:	1187235Click image for larger version
ID:	1187236Click image for larger version
                • simontie
                  • Jan 2010
                  • 1506
                  Ok before i put the fairing on a couple of naked shots :rolling:…. Of the Bike and front fairing
                  decals left to do I find them easier to do in place. Also new exhause carbon went on well i’m glad i changed them I even scrubbed the tyres, well next up will be finished build fingers crossed anyway:cold-sweat:
ID:	1187290Click image for larger version
ID:	1187291Click image for larger version
ID:	1187292Click image for larger version
ID:	1187293Click image for larger version
ID:	1187294Click image for larger version
ID:	1187295Click image for larger version
                  • simontie
                    • Jan 2010
                    • 1506
                    Morning
                    well calling this done decals on and she is in the cabinet a few issues with the decals most obvious the white panel at the front the day might come when i take this off and paint it but for now its fine one side when really well the other side broke up luckily I have managed to piece it all together so no biggie.
                    last issue was the fairing cowl classes with the instrument panel but its on and the gap is minimal so for now i will live with it all in really enjoyed this build just need to sort the decal issues not sure if its me or the ageing kits
                    simonClick image for larger version
ID:	1187317Click image for larger version
ID:	1187318Click image for larger version
ID:	1187319Click image for larger version
ID:	1187320Click image for larger version
ID:	1187321Click image for larger version
ID:	1187322Click image for larger version
ID:	1187323Click image for larger version
                    • Nicko
                      • Apr 2019
                      • 1402
                      • Nick
                      • East Anglia
                      Lovely finish on that red Simon, well done.
                      Nick
                      • simontie
                        • Jan 2010
                        • 1506
                        Nick
                        Thank you I was very pleased with it
                        • Mark1
                          • Apr 2021
                          • 4156
                          Very nice, a great addition to the cabinet.
                          • Mr Bowcat
                            SMF OG
                            • Dec 2016
                            • 4600
                            • Bob
                            • London
                            Very nice Simon. I think only you will ever notice the decal issue, it's not particulalry apparent in the pics.
                            • tigersteve
                              • Jan 2018
                              • 678
                              Another great build - very inspirational ( I must pull my finger out and finish my BMW :tears-of-joy: )
