Honda road racer 1/8th scale
  • scottie3158
    • 14198
    • Holbeach
    #16
    Looking good
    • outrunner
      • Apr 2019
      • 2420
      #17
      A lot of work but it will look great when done.
      Andy.
      • Mr Bowcat
        SMF OG
        • Dec 2016
        • 4596
        • Bob
        • London
        #18
        Coming along nicely Simon.
        Si vis pacem, para bellum.
        • simontie
          • Jan 2010
          • 1506
          #19
          First side done nipples still loose discovered i can true it up once all the spokes are in an then i will start trimming the excess and setting the nipples to hold it in shape. (Hopefully round)
          second side 9 left to go will try and get this one laced up tomorrow then start the front :surprised:
          Why is common sense not so common?
          • stillp
            • 8086
            • Pete
            • Rugby
            #20
            Originally posted by simontie
            nipples still loose
            Not often you read that on a scale modelling forum!
            Wheels are looking great Simon.
            • tr1ckey66
              • Mar 2009
              • 3592
              #21
              Fabulous stuff reworking the spokes, it makes a hell of a difference. Time consuming but ultimately well worth the effort.
              Cheers, Paul
              • Airborne01
                • Mar 2021
                • 3940
                • Steve
                • Essex
                #22
                I think this forum is becoming a dumping ground for innuendo, sly asides and all sorts of nippery slipple type jokes; I am actually appalled Sir! Keep 'em coming!!!
                • simontie
                  • Jan 2010
                  • 1506
                  #23
                  Thursday yippee, ok well managed to complete the rear wheel and it looks ok fitted the tyre for effect i need to paint the wheel now once i clean it all up Click image for larger version
ID:	1192045 started the front as you can see one side complete but a lot to do before i start the other side..
                  also I bought a new dermel drill stand seems ok used it on the front hub for the spoke holes
                  simon Click image for larger version
                  • simontie
                    • Jan 2010
                    • 1506
                    #24
                    Quite weekend so i have pieced some of the engine together lot of flash and mis matched parts in most cases i have just cut off the dowels and lined up by eye, lots of dressing up there seems to be a glaze over most of the parts i suspect a primer for the heavy chrome plating that took an age to dissolve
                    also finished the front wheel and primed it along with the rear wheel & engine Click image for larger version
ID:	1192333Click image for larger version
ID:	1192334Click image for larger version
ID:	1192335Click image for larger version
ID:	1192336Click image for larger version
                    This is a big engine shame theres not more detail & the primer has helped me id some other areas to work on the cylinder joins front to rear but you can clearly see the seam lines after i tried to dress them up more to do.…
                    simon
                    • Mark1
                      • Apr 2021
                      • 4156
                      #25
                      Good job with the wheels, sure the engine will be fine when your done, itll be hidden behind the fairing.
                      • scottie3158
                        • 14198
                        • Holbeach
                        #26
                        Simon,
                        The wheels look great, well worth the effort.
                        • Mr Bowcat
                          SMF OG
                          • Dec 2016
                          • 4596
                          • Bob
                          • London
                          #27
                          Wheels look awesome mate.
                          • tigersteve
                            • Jan 2018
                            • 678
                            #28
                            Great job so far ! Enjoy yourself .......
                              • 18883
                              Lovely job on the wheel lacing. Very impressive considering you used piano wire.
                              • simontie
                                • Jan 2010
                                • 1506
                                #30
                                Thank you all, I hope to do the rest of the bike justice i might have my work cut out but ill give it my best shot…
