Well back to the Bikes again,building this for a X-mas present so not much time left. Basic oob build with a few pe goodies sprinkled in.Here the basic parts and a few dry fitted components
Antena YZR500 1/12 Tamiya
GuestTags: None
Well knowing what you can get out of those Tamiya bikes, some one is in for a beaut of a x-mas pressy!
Ian MComment
Lovely metallic finishes again around the engine and framework. Absolutely superb looking model already.Comment
thanks Ian,Andy & Rich appreciate your kind words and yes Sarge thats Abe's old ride. I moved on to the tires while the paint was drying on some sub assemlies.
here they are untouched
then sanded with 80grit
next to simulate heat blueing I inked them with these sharpie pens
after applying
then I blended the ink and 'toned' it down with a soft clothComment
That's a great trick with the tyres there! If ever I get up the gumption to try a bike, I will have to remember that one.
Ian MComment
Thanks Adrian,glad you liked the tire trick Ian and you should pull the trigger on a bike build! I got some more forward progress tonight.Used the compass cutter to mask off the carbon brake discs and attached the swingarm. I just might pull this off before the fat man slides down the smoke chuteComment
