Diary of a Madman. Yamaha M1 2009 detail build
    And so it begins. Thanks to my recent separation from the missus ive been able to reclaim the spare room and turn it into a mess..just how i like to work!
    The project is a super detail build of Valentino Rossis' 2009 Yamaha YZR M1 world championship bike. This is my first time using upgrade parts and i want to make this my ultimate build as ive been in training for this one by using PE on earlier models and gaining more experience and knowledge from you modelling gurus.
    Heres a pic showing most of the parts!
    [ATTACH]53800.IPB[/ATTACH]
    some additional pics here.
    Ive snipped off the original plastic air valves from the wheels and drilled 0.55m holes to accept the Top Studio upgraded metal air valves. Ive also sanded the tiny molding seams the line the inside of the wheels and spokes..very time consuming..i dont know if these lines would even be visible but i intend to start as i mean to go on.
    The photos of the resin parts show where i have become a Jedi Master in the art of drilling pin vise holes! Theres about 15 0.5mm holes on the central resin part alone. I will be painting these semi black and covering with carbon decals. The tiny holes are to accept electrical connectors which will be a challenge as the connecting wires are 0.3mm and im also going to be using shrink tube where the wires enter the connectors. Ive never used shrink tube before so im stabbing in the dark. I just hope that the application of heat wont destroy the decals, so i'll try different heating methods on spare parts that applied carbon fibre to.
    I hope you find the pictures that i intend to add of interest and any fellow bike builders may learn from my inevitable disasters!
    [ATTACH]53801.IPB[/ATTACH]
    [ATTACH]53802.IPB[/ATTACH]
    [ATTACH]53803.IPB[/ATTACH]
    [ATTACH]53804.IPB[/ATTACH]
    [ATTACH]53805.IPB[/ATTACH]
      the site just froze, so i'll rewrite this post!
      Heres a few close ups of my progress. Ive prepped and painted the swingarm and added some very fine PE chain adjusters. I drilled out the original Tamiya molded screws that are in the rear of each swingarm leg with a 0.65 drill bit and inserted a short length of soldering wire instead. Onto the end of each piece i glue a PE washer and nut (slightly smaller than fairy dust).
      I dont know how well these tiny parts will hold up when i begin fitting the sub assemblies together, time will tell.
      I'll see if i can upload the pictures..if i do great, if not then the sites crashed again![ATTACH]51218.vB[/ATTACH][ATTACH]51219.vB[/ATTACH][ATTACH]51220.vB[/ATTACH]
      [ATTACH]53814.IPB[/ATTACH]
      [ATTACH]53815.IPB[/ATTACH]
      [ATTACH]53816.IPB[/ATTACH]
      • Andy2035
        • Aug 2011
        • 730
        One word so far...WOW...
          • 18266
          Looking like a good start.
          Just remember lots of light and plenty of pauses.
            How can you not read a thread entitled 'Diary of a Madman'! Fantastic. Hats off to you on the PE work too!
            Keith
              Originally posted by \
              Looking like a good start. Just remember lots of light and plenty of pauses.
              hahaha...ive been to anti natal classes to sort my breathing regime out!
              • Andy2035
                • Aug 2011
                • 730
                May I ask, how do you manage or even see all the small parts...
                  heres a few of the handlebar grips.
                  the clutch side has a resin part to accept a cable from the wheels sensor. This is a single molded part so i had to cut it in half very carefully so that i could glue it to the handlebars. Luckily, it didnt splinter and i didnt have bits pinging off into oblivion. I drilled a 0.3mm hole to accept a tiny wire but on the opposite side i drilled a shallow 0.6mm recess because i noticed on the real bike that the round barrel 'adjuster' is hollow.
                  On the throttle side, ive snipped off the original 2 locating pins that normally accept Tamiya's thin vinyl tubing, sanded the surface (1500 then 2500) and carefully drilled 2 small holes. One has to be very careful drilling these holes as its so easy to unintentionally drill at an angle through the part.
                  These holes are to accept the upgrade throttle cable separators. I did a couple of trials holes on some scrap pieces to ensure that i had the correct and a snug fit. I wont be able to do any more work tomorrow, but touch wood, i should be able to do some painting in a couple of days.
                  I have assembled my compartment box and have got various parts organised for painting. I'll only be painting black parts, either in prep for alclad, or semi black parts such as the handlebars, or for parts that will be carbon fibred.
                  [ATTACH]53825.IPB[/ATTACH]
                  [ATTACH]53826.IPB[/ATTACH]
                  [ATTACH]53827.IPB[/ATTACH]
                    Mate, im wearing one of those magnifyer headsets with the torch on top!!! I look like the serial killer from Silence of the Lambs....I wondered why the postie ran away screaming when i opened the door in my pants!
                      This is looking great! I'm getting the bike itch back just watching! Looking forward to the next update Funky!
                        Looking very good!!! Keep the updates coming friend!!
                        Polux
                          Ok, so heres a few detailed pictures of the work in progress.
                          The resin clutch has been painted alclad chrome and 1mm square pieces of masking tape added so that i can add clear red. This is then painted using the finest of brushes. a rubber surround is glued on and then some tiny bolt heads. before fitting to the engine i'll add more bolt heads to the clutch cover itself and also 3 decals to the black rubber ring around the clutch plate. These will be fitted once ive moutned the engine to frame, purely to minimise handling damage.
                          [ATTACH]53933.IPB[/ATTACH]
                          [ATTACH]53934.IPB[/ATTACH]
                          [ATTACH]53935.IPB[/ATTACH]
                          [ATTACH]53936.IPB[/ATTACH]
                          [ATTACH]53937.IPB[/ATTACH]
                          [ATTACH]53938.IPB[/ATTACH]
                            Next up:
                            a detailed pic of some PE work for the throttle cable assembly. First i removed and sanded the prongs from the Tamiya part, then drilled a small hole into either end of the plastic part. Threading the PE washer, then the 2 detailed plates and finally the top bolt onto 0.6mm soldering wire, i glued them carefully into postion using gator glue. The excess was removed with a damp brush and allowed to dry. I cut the soldering wire from behind the part leaving about 4mm as a dowel to screw into the hole. Once this was set i repeated on the other side:another 4 PE pieces. This was very fiddly as you can imagine!
                            The next pictures are of radiator parts. I used alclad dull aluminium for the main frame of the radiator and alclad polished aluminium for the pipe work and welding. Im going to repaint the filler cap as the finish isnt bright enough due to the black undercoat being uneven.
                            [ATTACH]53939.IPB[/ATTACH]
                            [ATTACH]53940.IPB[/ATTACH]
                            [ATTACH]53941.IPB[/ATTACH]
                              Bottom of fork leg masked prior to spraying semi black, plus a side view showing some of the PE engine detailing. Ive used a PE strap around the oil filter. I removed the tiny kink in the strap by rolling the part carefully in my hand. To secure the strap i folded 2 miniscule tabs over then applied a small amount of glue underneath before sliding the strap down to the base of the filter:
                              [ATTACH]53942.IPB[/ATTACH]
                              [ATTACH]53943.IPB[/ATTACH]
                              [ATTACH]53944.IPB[/ATTACH]
                              [ATTACH]53945.IPB[/ATTACH]
