This truck is sending me to the funny farm, when i removed the tape from the glass after spraying there were glue marks & paint all over them.
So i stripped the inside of the cab & removed the glass, but in doing this it broke of part of the window frame, so i have had to scratch build my own.
In the first pic it is all finished in pic 2 i have replaced the small window & am working on the door window ready to replace glass using clear plastic from an old packing box.
I have found the glass in this kit to be rubbish, as you look at it from different angles there are swirls & line's all over them & spoils the look, You can just see it in the first pic. so i am going to try & remove them all & replace them with clear plastic.
Ok then slow start on this one only started it last night, tanker built but will need sanding & filling, axles built & primed ready for red top coat, not going to do anything fancy with this one just a little custom spray job, Iridescent pink/gold fading into gloss black to match the truck.
