EMHAR 1/24 Bedford 'OLBD' Dropside 5 ton Truck
    Wow! Graham, I love your new build!
    Diferent and interesting. Uffff......and the weathering possibilities are amazaing
    Great choice!
      Nice subject Graham, I've always been a bit suspicious of Emhar kits after reading some poor reviews, but will definitely try them out some time. Looking good too!
      • Pikeman
        • Feb 2016
        • 1312
        #18
        Great work done on this Graham it's coming along nicely
          I like this, its looking good.
          scott
          • rickoshea52
            • Dec 2011
            • 4076
            • Rick
            #20
            what do you think of the Railmatch paints?
              Bit difficult to say on just the two colours Rick.  Not an expert on enamels either but I would say they were OK.  Need thinning for my .2mm nozzle and I got their thinners to start off with.  On thinning enough to get a decent spray, I found them a bit translucent.  It does say not to over thin for spraying but needs must.  I just needed to do more coats than I would with Acrylic.
              They are very slow drying.  I wouldn't want to be handling them much before 24 hours.  This may be due to the number of coats used to build up the colour.  It does say to wait 8 hours between coats.  Today I experimented and thinned with cellulose thinners which, bizarly, reduced the enamel smell and, expectedly, speeded up the drying.  Still very translucent though.
              My advise would be to select an appropriate primer colour.  White or light grey made the first few coats of Crimson very pink until I built it up.  The cream wasn't as bad but then again, I didn't have strong contrasting under coats.
              They are matt, or the two I used are and so will need a gloss coat of some kind.  I only want a semi gloss so I should get away with something like the Alclad Aqua gloss, which I trust and isn't too 'showroom glossy'
              In fairness, I have used them to get the authentic British Rail colours only.  I wouldn't have used them for anything else but for what I wanted, so far they have done the trick.
              • flyjoe180
                • Jan 2012
                • 12390
                • Joe
                • Earth
                #22
                Liking this Graham, very nice work so far
                • rickoshea52
                  • Dec 2011
                  • 4076
                  • Rick
                  #23
                  I never thinned to the level you have when using them but I use a bigger airbrush nozzle, two coats have usually been enough. They produce acrylics and varnishes too, I think satin is in their range.
                    Local shop only stocks the enamels, it if they do stock the acrylic, I didn't see them and they were out of stock of the varnish, only had matt.  But no worries, they are working fine.  Had a bit of a masking issue on the doors this morning but nothing that cannot be sorted.  Bonnet needs another coat after attaching the side panels but the mockup below shows how it will finally look.
                    I have learned do much from this build, patience being the biggest........
                      • 22770
                      #25
                      It's looking good Graham
                      • Gwyn
                        • Dec 2015
                        • 399
                        #26
                        Well done Graham, this is looking great
                          Excellent Graham that Bedford front end synonyms with that era used on everything from dust carts to removal vans. Good work.
                          Bob
                            Great work Graham.
                            The blood and custard colour's look spot on.
                              Looks great; beautiful colors!
                              • Pikeman
                                • Feb 2016
                                • 1312
                                #30
                                Think you nailed this one Graham,it looks perfect the colours are bang on.
                                great work
