Looking good Andy. Looks like the tracks fit pretty well despite the tricky build.
Mirror Models Bulldozer.
Cut off the locating pins on the last one, so it just slips between the one at the other end, then glue the two together?Comment
Andy.Comment
Not sure if I should have posted this in the weathering section but here is my first serious attempt at doing a bit of hairspray chipping.
Front belly plate under the engine.
[ATTACH]391095[/ATTACH]
[ATTACH]391096[/ATTACH]
Track suspension spring, ignore the brown bit as this gets stuck to the bottom of the engine and is not seen.
[ATTACH]391097[/ATTACH]
[ATTACH]391098[/ATTACH]
Still not too sure about the colour, I am thinking it is perhaps a shade dark but I will have a think about it.
All opinions and criticisms wellcome.
Andy.Comment
Andy,
That looks good and the washes later will help blend it all together and tone down the starkness.Comment
A bit more done tonight with the chipping, looks OK to me as I did not want to overdo it. When the tracks are on and I introduce some earth pigments or some equivalent muck they should be fine. A lot of work to do on the engine with paint and washes but it will get there, says he hopefully.
Thanks for looking.
Andy.Comment
I did a little bit of painting tonight and I thought while waiting for it to dry I will just build the dozer blade.
[ATTACH]391282[/ATTACH]
[ATTACH]391283[/ATTACH]
Well, that took longer than I thought, who would think there was 26 parts in that? If anyone wants a quick build kit then this is not it, loads of small parts, time spent making small adjustements here and there and time wasted looking through sprues for parts, but I love it as it is a great subject in my opinion.
Andy.Comment
Just had a nice catch up Andy. You must be pleased with your first big attempt at HS chipping. Great work all roundComment
