1/24 Italeri Peterbilt 378.
Well. that went very well, the chassis came together with no problems, no flash and built up square easily.
[ATTACH]416289[/ATTACH]
[ATTACH]416290[/ATTACH]
This kit was a present and I will admit to being a bit wary as my last Italeri kit did not go well but they must have upped their game as I have come across no major problems other than having to open out a few holes that were smaller than the pins on the parts which is nothing really.
The cab internals all done including the door pockets.
[ATTACH]416291[/ATTACH]
[ATTACH]416292[/ATTACH]
[ATTACH]416293[/ATTACH]
I did deviate from the instructions which would have you assemble the cab around the floor/dash components but on having a bit of a dry fit the cab internals can be fed up through the completed cab, then fit the door pockets and the windows before fitting the roof. I forgot to take pictures of the cab before painting and it is now being left to dry until tomorrow.
Andy.Comment
Got the engine finished.
[ATTACH]416698[/ATTACH]
[ATTACH]416699[/ATTACH]
[ATTACH]416700[/ATTACH]
Nothing fancy as I wanted a clean build out of the box so just did as the instructions called for although looking at the photos I notice a couple of bits need tidying up.
Last look inside the cab, a lot of work in there but when the roof goes on it will hardly be seen.
[ATTACH]416701[/ATTACH]
[ATTACH]416702[/ATTACH]
All the large chrome bits assembled.
[ATTACH]416703[/ATTACH]
Should not be long now but the sleeper and cab roof are to paint and laquer and there are 12 tiny decals to go on the chassis, something else that will go unnoticed.
Andy.Comment
I’m in Andy. Now your talking my language. I was 21 years old when I drove my first Peterbilt it was a 359. Never drove a 378 drove a 1989 379 in 1990 for a good friend of mine coast to coast. Looking goodComment
A bit of a dry fit to see how much the cab mounting needs to be tweeked to get a good fit with the bonnet.
[ATTACH]416982[/ATTACH]
The decals are not great as they do not match up to the hole for the air filter, the handle and the air filter mount, they are also not very high quality and I must have used about half a gallon of micro sol and they still sit proud in some places. The alternative would be to mask and paint them on but no way am I going down that route as I doubt very much if I have the skills to do that so they will have to be what they are.
Andy.Attached FilesComment
Should not be too long now, all major lumps are together just need to fit the decals (other words are available) and stick it all together, I mean, how hard can it be? :smiling5:
Edit. Just noticed I did not include the picture as I just pressed the post button and went to do something else.
[ATTACH]417212[/ATTACH]
