Scotties Miniart US Bulldozer
Why is it when I look for material like that I can never find it. I must be using the wrong expressions to search.Comment
Scottie
When I built my dozer, if I remember right I believe I built all the links together with a drop of glue one each end of the rod once it was long enough i joined it around the running gear and then placed the track pads on. I do remember it took alot of effort.
If I had known fruits did the tracks I would have ordered them from there aswell.
MartyComment
Sorry Scottie missed the fun and games
Reads like a bit of up hill battle? Of course you will beat it into shape
BobComment
Catching up here Scottie looks sublime so far and it seems to me you've got your head round this tracks malarkey, as you say no need to get brain strain!!
Keep up the excellent work
RobComment
Scottie
Marty
Cheers Rob, modelling should be fun it's not worth getting frustrated, part of the problem is probably me.Comment
The build continues with the construction of the blade this was all straight forward with no issues. You get the choice of the blade being turned right/left or straight ahead. I opted for the straight ahead.
I replaced the kit locking pins with copper wire, I also reasoned that as the pins were removable they would be on a chain to prevent them getting lost so added some etch chain.
finally added the toolbox with a bit of added bling from the spares box.
cheers
ScottieComment
Paul I found Russian version of the cat just as maddening with the tracks. As I hate tracks anyway other than Fruils I thought it was just me. Well worth having , ok they cost but it will make the whole build look much better . Can't believe Mini Art have made them awkward, not like them .Comment
