Keep it coming Mr Scottie...... she's looking the business alright!
Scotties Miniart US Bulldozer
Paul, I have 200% faith in you and your great skills my friend!!!..........Life's to short to be a sheep...Comment
The joys of model making mate. Now which bulldozer is it your building LOL
[ATTACH=CONFIG]n1177829[/ATTACH]
Here are some close ups if it helps. Plenty of reference photos if you need them. If it helps others have said this is the worst piece of the build. Onwards and upwards now my friend. Great work
[ATTACH=CONFIG]n1177830[/ATTACH][ATTACH=CONFIG]n1177831[/ATTACH][ATTACH=CONFIG]n1177832[/ATTACH][ATTACH=CONFIG]n1177833[/ATTACH]
Thanks Steve really appreciate the comment.Comment
Thanks Rick glad you approve.
Cheers Andrew
"Shortcut" routing - right side of right drum to over rear A-frame sheave, etc., etc.
[ATTACH=CONFIG]n1177839[/ATTACH]
Routing through fairleads - right side of right drum over upper-right fairlead to under lower-right fairlead to over rear A-frame sheave etc., etc.
[ATTACH=CONFIG]n1177840[/ATTACH]
Hope this helps. Was no fun in 1/87.
Thanks Rick.Comment
This may well become my very first shelf queen. I made s start on the tracks today and what PITA, each part has multiple sprue gates that need cleaning up and there is not one positive point of contact. The pin that joins the two sides of the links is loose in the holes both inner and outer so they flop about and the two location points on the top of each link are so badly moulded they do not fit the the shoe. I am in the process of trying to make a jig to hold the parts in the right place. The tracks have really let this kit down.Comment
Hi Scottie
Tracks are often a real trial but these sound impossible. Are there any aftermarket tracks available? If you can build a jig that should help. Could you replace the loose pins with a slightly larger diameter wire or styrene rod?
JimComment
Hey Paul, if the tracks don't work out the way you want, Friul Model makes a set of metal tracks for the D-7 (ATL-178) They sell for about โฌ19 for a set. maybe food for thought my friend..............
AllenLife's to short to be a sheep...Comment
Hi Allen cheers for that I might give them a look see. Hopefully I will find a work around.Comment
Just looked at the instructions for those tracks and they look a real pain to put together, much more complex than the tracks on the Mirror Models dozer I built which I thought were bad. Best of luck with them Scottie and I am sure you will manage to beat them into shape.
Andy.Comment
