Scania 770s 6X4 Tamiya R/C 1/14
    • 18257
    Sorry to disappoint but no in depth blow by blow account of this one. :disappointed: It is just a bit complex and I couldn't be stopping and starting taking pictures all the time, so insted you will get an up date as things progress.
    The basic build is, for the most part, finished. Now the real fun begins. Paint, electronics install then getting it all to work.
    The plane, from the start, has always been to get to this point then start the paint up. Some will build and paint step by step but to be honest far to much time cleaning up. So as normal for me I build all what I can befor I can see problems painting.
    With a more 'normal' kit, 1/35 armour or a 1/48 aircraft not a problem. But something this large.... I need a bigger desk!
    Tuff neighbourhood! lol The amount of screws picked up from the floor is beyond belief! Oh Mr Tamiya if your reading For the money we pay for these could you not consider giving us a properly sized JIS (?) screwdriver to make screwing the 500 screws in a little more fun and not a challenge.
    The thing on the letter scales is the battery holder that has The 'filter unit' one side and diesel tank (?) the other. The wheels are only the outer most of the rears and the two front ones. Most of the other bits here had chrome on of some sorts. After several different baths, the one that did the trick was drain cleaner.
    Bits of body.
ID:	1205377Click image for larger version
    The bottom of the cab, the lightbars and a few tread plates.
    more bits of bodywork!
    And here as well...
    A few tyres ! Annoyingly the rear tyres all have Tamiya as the brand ON BOTH SIDES, even though the instructions say that they are blank on the one side!
    The motor is not the one in the box, way to fast. This one is a motor for a rock crawler and is much slower and has a LOT more torque. The big black thing it is attached to is the three speed gearbox!
    The Scammel in the background IS 1/35 by the way.
    The big orange thing is the new Radio, my old one only had 6 channels, this one has 16 and S-bus! That should be fun to learn to set that up.
    Why strip the chrome. Well we all know that chrome on models is naff and look 'orid. (This however was actually very good and looked very nice). No I wanted to paint it a different way.
    Still going for the baby blue pearl but to 'toughen it up a bit' All the chrome will be replaced with Metallic grey aka Gunmetal.
    Comments and Questions welcome.
    'Til next time
  • Mini Me
    • Jun 2018
    • 10711
    Wow Ian, looks like you have every horizontal surface covered! Will you be scratch building a garage to park this in when it's done?
    • Gern
      • 9203
      I like this!
      I've bought Tamiya kits with that naff little screwdriver so I know what you mean. You'd be better off with a set of jewellers screwdrivers - even if you only use one of the set, you'll save yourself a lot of frustration and scrabbling around on the floor.
        • 18257
        LOL 100% correct Rick. Its everywhere!
        Once the finish paint goes down I can start to assemble.
        Originally posted by Gern
        I like this!
        I do have a set but a Phillips or Pozi-drive head are more pointy than a JIS and that means they hop out and do not fit squarely in the top.. Have found a set with JIS bits...
        As for the scabbling around on the floor, that's more down to my sausage fingers!
        • JR
          • May 2015
          • 18273
          If I can step over the screws I'll find a seat Ian .
          • Mini Me
            • Jun 2018
            • 10711
            I'll sit with JR and keep him from knicking yer hardware Ian.
              • 18257
              Not much to report today, Had a few bits that needed primer that I forgot yesterday. Well Forgot to wash them, this Tamiya is one of the slippery ever. Add to that the greasy fingerprints, and thread locker, and you know how that goes if you spray onto that. Not good. So they got a bath in warm soapy and dried off overnight.
              Today they got primer and a few of the bits from yesterday got a few touch ups here and there.
              Soon the real paint goes down!
              Pale blue Candy sprayed over either Titanium silver or Titanium gold. Which do you recon? I will have a play with that over the next few days and see which looks best.
              All the chrome bits are going to be Gunmetal grey.
              The inside of the cab will be done to match but just in ordinary matt and semi matt Black, Grey and Blue. Looking at lighting the cab. Also those position lamps along the sides and in the radiator mounted light bar and the sun shade are just asking for a light!
              • Mini Me
                • Jun 2018
                • 10711
                If it were me, I would choose the base that most compliments the trim color (Gunmetal) in this case, you will be the final judge once you have tried each base color under the top coat. Good luck.......and I would be interested in seeing the test results. :thumb2:
                • BattleshipBob
                  • 6785
                  • Bob
                  • Cardiff
                  Can I join in the fun sir, never worked on Scanias!
                  The unit you have on the scales is fuel tank and opposite looks the exhaust box which contains a very expensive SCR, selective catalytic reduction unit. This uses Addblue injected into the exhaust gases to reduce Nox. Like being back in front of a class lol.
                  Next to it is probably the Addblue tank, paint the cap blue.
                  Boring but over !!
                  • JR
                    • May 2015
                    • 18273
                    Can't advise on the colour , afraid only 4BO
                    • Andy T
                      • Apr 2021
                      • 3238
                      I've a good feeling the gold base will give you a green tinge. Yellow reflecting back from the gold, filtering through the blue candy.
                      Definitely worth testing first!
                      • Mini Me
                        • Jun 2018
                        • 10711
                        I had the same thought Andy, but thought it worth a try with both bases just to be sure. I also have the feeling that the Gold based would come out much darker than the Silver based top coat.
                          • 18257
                          I was going to buy a Tamiya silver spray then I saw the price. DOUBLE the price of all the others. (Gold was the same!) Are they made of real silver and gold?!?!
                          My hope it that the Titanium gold base will just give it a little warmth not sure I fancy a green truck....snigger snigger.
                          I will try and find the obligatory plastic spoons (which are getting harder to find these days)! and
                          do a batch of tests. Base colours up for the jury:
                          Titanium silver
                          Titanium gold. Both a nice gloss but not to vibrant a colour.
                          Metallic Gunmetal (same as the trim).
                          Thinking that the Vallejo model colour metallics with their (for once) nice large metal pigment might be a good "flake" substitute. I can buy real flake for airbrushes but I want subtle lol.
                          If The pearl can be sprayed over the Vallejo without burgering it up, I might try the silver, Aluminium, steel oily steel, gunmetal; both grey and blue! LOL I also have some metallic additive that can make any colour a metal. even a clear colour..... Hmm.
                          • Andy T
                            • Apr 2021
                            • 3238
                            Having had a quick Google it seems that name covers a wide variety of shades in modelling paints, some near the silver end, some much more golden, so you may well be right if it's not one of the yellow ones.
                            Good luck with all the testing. That'll probably take longer than the actual paint job lol, but worth it.
                            I did a couple of custom jobs some months ago with the same red candy. I put it over a fine silver on a Lambretta and over gold for a Triumph Bonneville. They came out quite differently, showing how important the base colour is.
                            • BattleshipBob
                              • 6785
                              • Bob
                              • Cardiff
                              Forgot Ian the exhaust will either have a chrome heat shield or be behind a grill/frame etc
