Revell 1/24 Unimog Rallye.
    [ATTACH]103883.IPB[/ATTACH]
    [ATTACH]103884.IPB[/ATTACH]
    [ATTACH]103885.IPB[/ATTACH]
    [ATTACH]103886.IPB[/ATTACH]
    [ATTACH]103887.IPB[/ATTACH]
    Finally finished what as been My Build From Hell, with a Senior Moment & forgot to mask the windows before gloss varnishing. You will notice one of the problems with this build is how the tyres will not stay on the wheel rims.
    At least I think I got it to look reasonable once finished & hope you like the photos.... Now onward & upwards to the next build .
    [ATTACH]103878.IPB[/ATTACH]
    [ATTACH]103879.IPB[/ATTACH]
    [ATTACH]103880.IPB[/ATTACH]
    [ATTACH]103881.IPB[/ATTACH]
    [ATTACH]103882.IPB[/ATTACH]
    • 18272
    Well despite it being the truck from hell you made a pretty good job of it.
    A bit late now but if you can get the tyres off, you might be able to persuade them wider with hot water and something to hold the tyre open while they cool. Then glue the pesky things to the outside rim first.
    A great truck though well done.
    • PaulTRose
      • Jun 2013
      • 6559
      • Tattooine
      well i like it a lot!
      Per Ardua
        Looks great to me...... A top job
          Hi Ian, there would be no problem in getting the tyres off, only need to pick the truck up turn it on its side & give a little shake & the tyres will fall off the wheels lol.... the inner diameter of the tyre is about the same as the rim diameter of the wheel & with the movement of the soft tyre I think it would not stay glued for long. Thanks anyway.
          John.
            Thanks Paul.
              Thanks for the comment Amos.
              John.
              • monica
                • Oct 2013
                • 15169
                looks good to me and a nice clean build,
                • flyjoe180
                  • Jan 2012
                  • 12476
                  • Joe
                  • Earth
                  Nice job John, looks good to me. I wonder if you could stuff the tyres with something like a foam to push the shape out?
                    Thanks Monica, for the comment & great build rating.
                      Hi Joe, Stuffing the tyres would be no good as the hole in the tyre is the same size as the rim of the wheel & so the wheel just goes straight through the tyre with not enough of a rim on the wheel to hold the tyre in place.. Thanks for trying to solve the problem.... .
                      John.
                        • 22788
                        Great work John looks like no trouble at all, that just shows how good it is
                        • Robert1968
                          • Mar 2015
                          • 3596
                          Great work and it's a shame about the tyre situ ( I was thinking if you could make some large rings from styrene and extend the rims ( from rear) and position tyre then ring and affix with clear glue? Or I may be thinking too hard on this one
                          I do like the build though
                          • takeslousyphotos
                            • Apr 2013
                            • 3900
                            That's a really superb job John, I like that a lot. Five Big Stars for that.
                            Peter
                              Thanks Ian .
                              John.
