Mock up glue
  • Jabba
    • Feb 2023
    • 113
    Mock up glue
    Hello all,
    I would like your words of wisdom on something.
    I need to know if theres a glue I can use for mocking-up i.e. test building subassemblies or panels etc before painting to make sure of a correct fit , or , when scratch building, trying out the fit of an engine/transmission/suspension in a pretty solid way, but then being able to un-glue everything for painting?
    I often see on-line, especially from USA model builders, custom cars built completely 'in white' to make sure everything fits. You can't tell me they paint them built-up like that so they must use some glue which can hold it all in the correct position but can be dissolved after.
    The ones I have asked about it have said they use 'white glue' which I'm thinking means PVA?
    What are your thoughts?
    Yours
    Peter
  • Geoffers
    • Jan 2017
    • 1635
    • Geoff
    Yep, PVA glue seems to make sense.
    Not sure how they go about it as I really struggle with PVA as it seems to take forever to set.
    I sometimes use a tiny and I mean tiny bit of CA glue to hold pieces in place when I’m test fitting. The parts then come apart with a little bit of pressure.
    I clean up with a wipe of de-bonder if necessary.
    Geoff.
      • 18868
      Probably studio gum (it replaced the latex cow gum) I think. I used to use it to stick the little blokes to painting sticks before I discovered blue tac. When dry it just rubs off the surface. Could also be copydex, which is very similar.
        • 15595
        Could you use a few dots of masking fluid???
