The Lambo has ground to a halt......... I'm Gutted.
  • takeslousyphotos
    • Apr 2013
    • 3900
    My Lamborghini Countach build has come to a grinding halt .......... I started looking at the the body and cleaning up the parts. and there is a bit missing. The right hand door vent
    I bought this as a part built and for reasons best know to the original owner a lot of the parts were off the sprues. I checked everything as best I could but I guess I missed this bit. I've struggled with badly fitted parts, broken parts and a couple of other missing bits that I managed to fabricate........ But this missing door vent is "the kicker"....... I've proper had enough of it and I'm gutted.
    I'll have a look tomorrow to see if I can fabricate something. But If I do, then I'll need to do bothe sides to match..............But it'll probably just get shoved back in the cupboard.
    [ATTACH]110899.IPB[/ATTACH]
    [ATTACH]110900.IPB[/ATTACH]
    [ATTACH]110901.IPB[/ATTACH]
    • 22770
    That's a pity Peter I hope you can get it sorted
      You will manage something... I'm not as good at building as you and have nearly recovered the Ferrari I pretty much melted! I'm sure with a bit of effort you can have a bit of fun either fixing or modding this.
      • Adrian "Marvel" Reynolds
        • Apr 2012
        • 3008
        The part you have, is the lost part identical to it?
        Just thinking you may try doing a resin cast of it?
        Adrian
        • flyjoe180
          • Jan 2012
          • 12399
          • Joe
          • Earth
          Out with the plastic card, see if you can scratch something up.
          • takeslousyphotos
            • Apr 2013
            • 3900
            Adrian
            No I'm afraid not Adrian............ One is left hand and One is right Hand.
            • takeslousyphotos
              • Apr 2013
              • 3900
              Yes I think I'll have to do that .......... I have a couple of ideas now to scratch something for both sides so they are identical.
              • takeslousyphotos
                • Apr 2013
                • 3900
                Thanks Dougie ...... I have a couple of ideas to scratch something up.
                • PhilJ
                  • May 2015
                  • 1145
                  What a pain! Good luck with that
                    Good, I look forward to it...
                      Hope you can manage to make a new part. That's the trouble buying uncompleted kits, you never know if everything is in the box.
                        Bummer don't let it beat you, even if you put it away for a while and get it out when you are feeling better about it, good luck.
