tamiya mini cooper
    tamiya mini cooper
    i have a tamiya mini cooper 1:12 i got a short while ago
    and im gonna start to build it but wonwinglow i think it was said you need to clean the part to get rid of the release agent
    so my first question(many more to come no doubt)
    what do i use to clean the parts ?
  • John
    • Mar 2004
    • 4646
    • John
    • Halifax
    Warm water, a bit of thinners and a little bleach, leave to soak.
    I might be wrong on this but I asked the same question
    www.scalemodelshop.co.uk
      im not to happy about using white spirit/thinners as the last time i got it on a model (white spirit) it coroded the plastic
        the other thing to use which is a mild degreasant is lighter fuel, mix a little bit of lighter fuel in with hot water and then soak.......use the lighter fuel as it removes any grease or release agents( the liquid not gas !) and then leave to dry........
          i just use washing up liquid and a tiny bit of bleach in hot water. never failed me yet! they always say to let it air dry but i tend to stick mine on a clean towel in the airing cupboard....never done any harm to any models so.....
          oh yea, i dont know if you have read my enzo thread but here is a tip for tamiya kits....
          a little tip....if a Tamiya kit asks you to paint a piece that is already black with Semi-Gloss Black (x-18) dont bother, it dries the exact colour and texture as the plastic so its a waste of time and paint. if there are other bits to paint other colours, do them and if you mess up a bit, just touch up with the x-18....if you dont believe me, try it on a bit of spu and see for yourself!
            hmmm
            i knew that lighter fluid takes of the grease and stuff but being a non smoker and having no lighters i dont have any
            i will maybe try a bit of bleach or detergant and see how it comes out
            also how long do i leave it to soak ?
              Over all the years I have been doing this I have used no more than warm water with a bit of fairy in it. Little corners, nooks and crannies etc, get a bit of fairy on a toothbrush.
              Rinse with warm water and dry. Any other chemical has a potential for affecting the plastic and I really don't think it is necessary.
                Over all the years I have been doing this I have used no more than warm water with a bit of fairy in it. Little corners, nooks and crannies etc, get a bit of fairy on a toothbrush.Rinse with warm water and dry. Any other chemical has a potential for affecting the plastic and I really don't think it is necessary.
                I 100% agree, this method is what i use and has never let me down!
                Ive actually written a tutorial on "washing" ......
                http://www.semodels.com/washing.php < read it here
                  I 100% agree, this method is what i use and has never let me down!Ive actually written a tutorial on "washing" ......
                  aha
                  i never thought of looking there
                    Thats prolly because theres only about 5 uploaded at the moment, lol!
                      Washing up liuid and warm water thats it dont bother with anything else unless your using resin or white metal
                        ok i will clean them tomorrow after college :smile11:
                          started building it
                          go the engine glued together will paint it tomorrow after college
                          pics will come tomorrow also
                            my humbrol red paint seems to be taking forever to dry
                            does anyone have any idea why
                              did you give the pot a REALLY good mix before applying it? Is it gloss?
                              Also - quick tip if its still drying, place a mixing bowl over the model or dust will settle on it, and then dry into the paint!
