Project Merlin
  • Pr.Merlin
    • Feb 2021
    • 96
    #76
    Hello Folks - update No. 2.
    I'm a bit rusty with the old woodworking craft. I had briefly forgotten how time consuming it is marking up, but I remember now! :smiling: :thumb2:
    Firstly, I ordered a new backdrop for photographing the work a couple of weeks ago. It arrived last week but was sadly unusable. Long-short: I exchanged a few emails with the supplier and have now been fully refunded without having to return the backdrop - a nice little bonus I guess - will use it for something. I've since ordered another drop very similar to my previous one from the old workshop - it should arrive any day now. Just thought I'd ramble on a bit and mention this minor detail.
    All of the components in the five frames are now marked up excluding the braces and the narrow studs. That's 129 components and 184 mortice & tenon joints. The workshop is now clean and tidy (just thought I'd mention that bit too) and ready for crafting the joints.
    This photo was during the setting out and marking up process. I had to adapt my old bench hook which is now in the well of the bench instead of hooked over the bench. This is purely because I don't have the room behind me for sawing. I have also been using the jack plane to clean up pieces of timber I ripped down for the narrow studs.
    And here are all five frames marked up and ready for action.
    You can also see the plinth splayed posts in the above photos which are for the porch and rear frame. The two with the lower mortices already chopped out in the plinths are for the rear frame and the other two (on the right) are the porch corner posts. Here they are below more closely.
    If you can see a couple of the top halves slightly leaning, it's because I haven't glued them yet and they're sitting on slightly cupped joint dividers.
    I really like this subtle feature, especially with the joint dividers which is 2.4mm oak construction veneer. I'm unsure whether to leave these in natural oak or paint them in the accent black before glue assembly - as per drawings. I think I fancy the black. :thinking:
    I love projects like these, because they can change a wee bit as the work progresses. When I designed Project Merlin, I included 4 spiral stair possibilities. I have now designed/merged another possibility and I'm really drawn to this one. So much so, I've ordered 4/25mm hand blown glass beads which I'm hoping I can use for the lamp feature on the stair column.
    Here is spiral stair No. 5 - the column will made using cocobolo; a tropical South American hardwood. I hope to replicate this as an actual bole of a tree. The quad lamp stand will then elevate from a coned cap and branch out into the roof space with the 4 glass spheres hopefully glowing with a welcoming warmth of beauty.
    That's it for now.
    Many thanks.
    • wotan
      • May 2018
      • 1150
      #77
      Paul
      A great start on this fascinating project. The stairs with those lamps shades will look really nice.
      • Pr.Merlin
        • Feb 2021
        • 96
        #78
        Originally posted by wotan
        Paul
        Hi John. Thanks very much. :smiling4:
        • JR
          • May 2015
          • 18273
          #79
          Morning Paul.
          Some neat sections on the bench awaiting further work.like the glass beads you have obtained.
          I see you have been drawn in to the world of the TBC, they are well known for such subterfuge in obtaining members. Be aware next year's subscription will probably mean you will have to sell your soul to the devil at the crossroads.
            • 15699
            Hi Paul
            Already the work is impressive. Very neat and tidy.
            Are all the joints made using hand tools or do you have some sort of machine?
            • Pr.Merlin
              • Feb 2021
              • 96
              #81
              Morning Paul.
              Morning John, yes, I'm hoping the holes in the glass beads are going to be large enough for a small LED to fit into. I did some homework before buying them - fingers crossed.
              Haha, indeed - the TBC. The secretary and myself have exchanged a few promising emails. :smiling:
              • Pr.Merlin
                • Feb 2021
                • 96
                #82
                Originally posted by Jim R
                Hi Paul
                Hi Jim, thanks very much. :smiling4:
                Yes, all hand tool work so far, although I still have a small bandsaw and bench mortiser from the old workshop days. Although, I used to use the mortiser as a pillar drill instead of a morticing machine. With so many mortises to chop out, I might rig up the old mortiser, but all the tenons will be cut by hand. I'm also contemplating making my own bricks and roofing tiles from the oak construction veneer. If so, I shall clean up the bandsaw for ripping down. I've calculated about 1,600 brick slips. :thumb2:
                • GerryW
                  • Feb 2021
                  • 1757
                  #83
                  Just caught up with this - lovely work (my wood butchering skills is more suited to firewood!)
                  • adt70hk
                    • Sep 2019
                    • 10409
                    #84
                    Paul
                    Just had a quick catch-up. It's very impressive - and that's just your workshop!
                    The start of the build is also looking good so far.
                    ATB.
                    • boatman
                      • Nov 2018
                      • 14478
                      • christopher
                      • NORFOLK UK
                      #85
                      Hey, thereโ€™s a Perishers fan in the house.....youโ€™ve just name dropped the Bloodhound Jim! Next up, the eyeballs in the sky!
                      HI Tim yea im a Perishers fan also got a big book with them all in love the eyeballs in the sky lark where they was goin to launch a brave crabonaught beyond the relms of the pooliverse that cartoon strip had me thinkin an laughin for days an still does but in my opinion its not as good as it used to be but still funny an cheers me up what with all the rest of them
                      chris ps sorry paul for hijackin your thread on this
                      chris
                      • Pr.Merlin
                        • Feb 2021
                        • 96
                        #86
                        Thanks Gerry - I'm sure you're being modest. :smiling:
                        • Pr.Merlin
                          • Feb 2021
                          • 96
                          #87
                          Originally posted by adt70hk
                          Paul
                          ATB.
                          Thanks Andrew. Yep, the workshop is always organised and tidy - tidy 'shop, tidy mind is my geeky philosophical methodical OCD approach. :nerd:
                          • Pr.Merlin
                            • Feb 2021
                            • 96
                            #88
                            chris
                            No worries ole chap. I haven't a clue what you guys are going on about, but I laughed anyway. :smiling:
                            • boatman
                              • Nov 2018
                              • 14478
                              • christopher
                              • NORFOLK UK
                              #89
                              HI Paul its a cartoon strip in the daily mirror just below andy capp
                              chris
                              • Pr.Merlin
                                • Feb 2021
                                • 96
                                #90
                                chris
                                Hi Chris - oh I see. :thumb2: :smiling:
