Andrew's resurrected 1/72 Armourfast Farmhouse....
  • adt70hk
    • Sep 2019
    • 10409
    #16
    All looking good Andrew.
    A couple of pointers.
    Hang loose and don't try and copy anything, just follow his basic rules and free flow....
    Don't be worried about letting one colour run into the next.
    Relax! It's only a roof. :upside:
    Your lady Chinese Roofer.
    Ty Ling
    Miss/Ms/Mrs Ling (sorry I don't know your marital status so am covering all bases).
    Thank you for your wise words of wisdom. They shall be in the forefront of my mind as I tackle the 1360 tiles...it seemed such a good idea at the time!
    Ever yours
    Andrew, Ty Ling apprentice!
    In all seriousness Ron, good to have someone of your calibre aboard! And you make a very good point about not being too precise.
    Originally posted by Jim R
    Hi Andrew
    I reckon you're onto something with the multicoloured tiles and bricks of long ago. Look forward to seeing your efforts.
    Thanks Jim. I hope I can pull it off.
    ATB.
    • adt70hk
      • Sep 2019
      • 10409
      #17
      Originally posted by Ian M
      That jagdpanther dio he's doing/done is well nice. What he gets out of those blocks of foam is wizardry !
      I don't know if they would work in the scale you are doing but the seeds from a silver birch has very similar form to ivy leafs.
      Indeed it by is. I've probably been watching him for about three years and watching how he's come on had been brilliant.
      He comes across as a genuinely humble individual and doesn't claim to know individual.
      I'll have a look at birch seeds. Thanks for the tip.
      ATB.
      • eddiesolo
        • Jul 2013
        • 11193
        #18
        Well, what a transformation Andrew, lovely work on the brickwork. I think this is coming along rather nicely, should look outstanding when finished. Love the vine/string approach, once painted, it will add detail to the wall.
        • adt70hk
          • Sep 2019
          • 10409
          #19
          Thanks Si, much appreciated.
          I started it so long that I can't remember what made me think of string. PVA obviously didn't cut the mustard when it came to attaching it to the wall but the superglue worked surprisingly well.
          Thanks for stopping by.
          ATB.
          • spanner570
            • 15391
            #20
            Andrew,to my eternal shame I completely missed your mention of roughing up the walls. The effect is excellent.
            Very well done that man!
            • adt70hk
              • Sep 2019
              • 10409
              #21
              Thanks and no need to feel any shame.... Let's face it there is a lot of waffle in the above posts. :smiling5:
              ATB.
              • adt70hk
                • Sep 2019
                • 10409
                #22
                Good evening all
                So I spent a thoroughly enjoyable hour on Sunday evening doing some of the tiles. I started very carefully but the first colour was closer to the base coat than I thought, so stepped up to something with more contrast and took it from there.
                I also started with very thin coats, so as to not risk overwhelming it with one colour that would then stick out like a sore thumb - especially as lighter shades can sometimes 'pop' a bit too much at this scale.
                An unexpected benefit of this approach was that it allows the base coat to come through a bit, as a sort of pre-shade. It also means I can add two or three more layers of each paint to help with the tonal variation of each colour I have on the mixing palette - effectively creating two or three variations of each colour - and doubling or trebling the number of colours in use without opening a lot of paints. It also helps to stop it looking too 'toy' like.
                I had to stop for dinner but that was probably not a bad thing as it forced me to stop and take stock of where I'd got to.
                I'm going to do a few more tiles from the initial colour palette below, before moving onto some lighter colours now I have the hang of it - I reckon I've done no more than a quarter so far and probably less
                Below are two pictures from each side - one close up and one from a more normal viewing distance of about 3 feet, although it looks farther away than that.
                Please be honest with your comments!
                ATB
                PS it's all a bit browner/darker in real life....
                The initial colour palette...
                After one hour.....
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  #23
                  Thats excellent Andrew!!
                    • 18901
                    Liking that Andrew, colours look spot on.
                      • 15687
                      Hi Andrew
                      Colours look fine to me.
                      • adt70hk
                        • Sep 2019
                        • 10409
                        #26
                        Hi Andrew
                        Thanks gents, it's not a bad start even if I do say so myself!:smiling3:
                        Let's hope it continues!
                        ATB
                        • adt70hk
                          • Sep 2019
                          • 10409
                          #27
                          Thanks again all for the support
                          So I had a bit more of a play with a brighter colour last night.
                          At first glance I thought it stuck out too much but then it occurred to me that I've been using pretty muted colours so far and so that as I add other lighter/brighter colours, it will look less obvious. That said, if it is too bright I can always tone it down a bit.
                          As before it's a bit darker/browner in real life
                          ACW please!
                          • Steve Jones
                            • 6615
                            #28
                            Brilliant work Andy. Very impressive
                            • adt70hk
                              • Sep 2019
                              • 10409
                              #29
                              Thanks Steve. It's not looking too shabby even if I say so myself!
                              ATB.
                                • 15687
                                Hi Andrew
                                Most definitely not shabby.
