Andrew's resurrected 1/72 Armourfast Farmhouse....
  • adt70hk
    • Sep 2019
    • 10400
    #76
    Good morning all
    So more progress on the base yesterday.
    Junior and I spent a nice hour or so working on the substructure for the base which I covered with bog-standard polyfilla (aka spackle to our North American members).
    Small stones and various grades of sand were then placed on/sprinkled over the based to add a bit of texture, which was then followed up with a a coat of very thinned PVA to make sure it was all sealed on properly.
    Next up is the primer.
    ACW as usual.
    The substructrure
    You may recall that when we first joined, I posted some picture of hills made from that expanding insulation foam (link HERE).
    Well I still have some lumps left and also kept some of the waste material, including very shin sheets of it that had been stuck to plastic sheeting we used to squirt it onto.
    It was cuts from these sheets we used to create the substructure. Stupidly I forgot to take a picture of it before I applied the filler but you'll hopefully get the idea from the below shot.
    The finished base
    Below is the finished based ready for priming and with the house on. I actually masked the based off to make sure it didn't get contaminated by the filler.
    As you can see there is a slight gap around the base but the flock should hide the worst of that, although I've just noticed I got the placement on one of the stones but the backdoor wrong so I will have to move that.... :sad:
    The lighter sand is finer sand for the paths as the course stuff was a too heavy to my eye.
    • Mini Me
      • Jun 2018
      • 10711
      #77
      That's impressive Andrew......I think I will be trying some of your ideas on the next base I do. Well done :thumb2: Rick H.
      • adt70hk
        • Sep 2019
        • 10400
        #78
        Good evening all
        So the base and first floor have had a primer coat of black matt rattle can paint - nothing flash, just basic car paint.
        Now it's all tied in with one colour, I'll start on the wooden floors next. I just need to let it dry properly - 24 hrs according to the can.
        ACW as usual.
        • adt70hk
          • Sep 2019
          • 10400
          #79
          Thanks Rick. Much appreciated.
          To be honest though I have begged, borrowed and stolen a lot of the ideas I use - and then adapted them. Although once in a while it turns out that I come up with an idea on my own which is then demonstrated by someone online.
          In terms of inspiration the big one for me has been a guy called Mel Bose aka The Terrain Tutor. His work is aimed at the wargamer and runs from very simple techniques to quite complex ones that should come down to your scale. Unfortunately, his YouTube channel has gone very quite, although that's in large part to him focussing on his book., which is very, very good indeed. Link to YouTube below.
          His book is called Terrain Essentials. You can get it in the US in hardback or PDF only. Look here for more info - you have to scroll down a bit: https://www.davetaylorminiatures.com/publishing/
          I also stumbled across another wargaming terrain blogger - not on YouTube and much smaller but still very useful, although again he's gone a bit quite. He's called Greg and is in South Africa (link below).
          There's another Brit I've found called Luke of Geek Gaming (it was APS previously). Quality wise he's probably a step up from Mel for some things but none of it is out of reach - that said from a distance some of it looks as good as a lot of dioramas I've seen. He has his own shop, so he does plug his stuff occasionally but not to an annoying level. (link below).
          Hope that helps and thanks for joining me on the journey.
          ATB
          Mel Bose aka Terrain Tutor
          Luke of Geek Gaming Scenics
          • Lee Drennen
            • 7711
            #80
            Nice updates keeping Junior busy is a good thing and heโ€™s learning
              • 18892
              Agree ref. Mel Andrew. He has gone very quiet since the book, but he has had a lot of personal issues, not least popping a lung during his covid infection. I think he is now focussed on commission builds, as is Lukeโ€™s Apsโ€ฆ
              • Mini Me
                • Jun 2018
                • 10711
                #82
                ATB
                Thanks Andrew......will check 'em out.:thumb2: Rick H.
                • adt70hk
                  • Sep 2019
                  • 10400
                  #83
                  Indeed a lot on for one person.
                  In case you hadn't heard his marriage also came to an end, plus some mental health issues, plus money worries.
                  In one of the Sunday Nighters before Christmas he basically asked people for money to tide him over, in part because his Patreon revenue had dropped off significantly - presumably because people stopped supporting because he wasn't posting new content. Such a shame for such a genuine bloke.
                  ATB
                  • adt70hk
                    • Sep 2019
                    • 10400
                    #84
                    Hope you find them useful. If you want to take things to a whole new level, look up Night Shift and some of his recent builds.
                    ATB
                    • adt70hk
                      • Sep 2019
                      • 10400
                      #85
                      Thanks Lee, we try to keep him out of mischief....and off the screen!
                      ATB.
                      • adt70hk
                        • Sep 2019
                        • 10400
                        #86
                        Good morning all
                        So the base has seen some paint, as have the floors.
                        The base was done with a mixture of cheap children's paints, some DIY paint tester pots and Humbrol's and Revell's Dark Earth (not that the Revell one is in the least bit dark). I'm not sure if the paths will need a coat of slightly lighter colour paint, I'll wait until I have the flock down.
                        The floors were done with a couple of heavy washes of Humbrol's enamel Natural Wood 110 to give a used effect. I was probably a little heavy in hindsight and should have done lighter coats as I've done previously when using the technique.
                        ACW as usual.
                        FYI - the base is a tad darker/browner in real life but you get the idea.
                        • JR
                          • May 2015
                          • 18273
                          #87
                          It's really nice to see that junior spends time with you modelling. Something Andrew he will remember all his life .:thumb2::thumb2::thumb2:.
                          • adt70hk
                            • Sep 2019
                            • 10400
                            #88
                            Thanks John. He seems to enjoy it most of the time.....it's my painting dragging on that bothers him!!! :sad: :smiling5:
                            When it comes to the Soviet Tank GB though it's my intention he does it all!
                            ATB.
                              • 15669
                              Hi Andrew
                              Base looks to be progressing well. I agree with John it is great that Junior likes sharing modelling with you.
                              • Allen Dewire
                                • 4741
                                • Allen
                                • Bamberg
                                #90
                                The base is looking fantastic Andrew!!! Kudos to you both you and Junior. I see some of the ads on the newspaper under it offer things that would REALLY set it off. The fruit trees are a little pricey though........and maybe a tad out of scale too. I would check into the patio mounts though..........
                                Allen
