KrystalKleer does just that. I think designed for canopies but has many uses. I've used it in 1/87 scale to make windshields/windows. White glue like Elmer's also dries clear. PaulE
Micro work
Hi Kelly,
I'm not familiar with Paul's product, but it sounds good.
I'm also not sure exactly what you mean by 'camouflage brush'. If you mean the bits of 'tree' or branches then I use a glue similar to PVA which we use at work. It's a little stickier or rubbery than PVA and we call it 'Emulsion glue'. PVA would work just as well. I have thin nozzles on the end of the bottle so only tiny drops come out. I would find CA a bit too instant and unforgiving. With PVA you can at least push it around for a while, until it's just how you want it. I hope this helps and am always happy to answer questions.
AndyComment
Hi Kelly,
Andy
Cheers.Comment
Hi Andy
Relatively new to the forum so missed the start of this thread. I have no idea how you do it at that scale. I used to wargame with 1/300 scale stuff in my youth, so I know how small that stuff is.
As for the display case a simply brilliant idea excellently executed.
Well done.
AndrewComment
